Breadcrumbs functionality
Before I started hacking on the header templates I wanted to check if there was a better way to add breadcrumbs. I didn’t see any obvious way to enable that functionality.
I saw another post here detailing how to use tags. Is that still the recommended way?
Are you referring to this post?
I would say this is the best option :blush:
That would be the one. :slight_smile:
Thanks!
