Hi all,
Are the integrations listed under the integrations page considered custom? I hope you’ll forgive this question if it seems rather simple, I’m just confused about what’s considered a built-in integration vs custom and I can’t find an answer anywhere in the Ghost documentation that makes it clear.
I’m a newbie to Ghost and currently on the Creator plan, using a free official theme (Dawn). If I wanted to add integrations from the list above, can I get away with the Starter plan, or are they all considered custom integrations?
Thanks!
