Fill out the following bug report template with as much detail as possible!
Are you sure this is a bug? If you just need help, post in the developer help category. If it’s a feature request, head to the ideas category.
Issue Summary
- Explain roughly what’s wrong
- What did you expect to happen?
First i could not backup my content, everytime I try to export the content, the Ghost crashes and restarts,
Also, I could not upgrade Ghost for about a month of so now, always with the following error:
A GhostError occurred.
Message: Ghost was able to start, but errored during boot with: Migration lock was never released or currently a migration is running.
Help: If you are sure no migration is running, check your data and if your database is in a broken state, you could run `yarn knex-migrator rollback`.
Suggestion: journalctl -u ghost_104-248-84-14 -n 50
Steps to Reproduce
- This is the first step…
- This is the second step, etc.
I created another droplet on DigitalOcean, created a fresh Ghost install, then restored the SQL dump, to the “ghost_production” database, everything went smooth, however, trying to upgrade it was the same issue.
Upgrade to: “5.98.0”
Stucked Ghost versions on two servers (unable to backup or upgrade):
5.88.2 and 5.89.6.
I tried the same on even a local machine and got the same error.
I ran the log several times and there is nothing list the real issue, as always that i have to run “yarn knex-migrator rollback”.
Setup information
Ghost Version
Share which version of Ghost you’re using.
Node.js Version
If self-hosting - share which version of Node.js you’re using.
How did you install Ghost?
Provide some details about your install of Ghost if you are self-hosting.
Include further details about your hosting and OS.
Database type
MySQL 5.7 / MySQL 8 / SQLite 3 / Other
MySQL 8
Browser & OS version
Include if reporting frontend bugs.
Relevant log / error output
Copy and paste any relevant log output. Use backticks to format this into code.
