Casper locale is not working
I have put this file WorldCasper2/es.json at i18n-translatable-frontend · juan-g/WorldCasper2 · GitHub at the /var/www/ghost/content/themes/casper/localess path
I have set “es” as language on the Admin panel
I have executed successfully “ghost restart” on the ghost directory. But everything is still on English
Possible 3.0 bug?
@Luis the default Casper theme does not use translation helpers, if you want to use the WorldCasper2 es.json locale file you’ll need to use it with the WordCasper2 theme.
But I understand that if I use that repo I won’t be enjoying great things like the dark mode. I could try to translate the 3.0, but having to work each time you update the theme is far from great.
I understand that this is your native language, but please, support localization so non-tech people can enjoy it.
Thanks for your time!
