Changing font size of text in code blocks of my ghost blog
I’m using casper theme in my ghost blog.
Here is my url - shifatearman.com
I’ve added the following code in my site footer using code injection option for formatting my code-
After clicking save, the changes take place. Here is an screenshot.
The problem is - the font size of text inside my code block seem to be larger than normal. I didn’t want to increase the font size.
How can I reduce the font size?
Could you turn off the private mode so we can see your issue on the site? It’ll help us to debug it better :slight_smile:
Oh sorry. Should have noticed it earlier. I turned off the private mode.
This piece of CSS should reduce the font size within your code blocks:
<style>
  pre[class*="language-"] {
      font-size: 0.75em;
</style>
Drop that into your site header code injection area :+1:
I dropped the code in the header section of code injection area. But it’s still the same.
Here is my footer -
<script src="https://cdnjs.cloudflare.com/ajax/libs/prism/1.16.0/prism.min.js"></script>
<link rel="stylesheet" type="text/css" href="https://cdnjs.cloudflare.com/ajax/libs/prism/1.16.0/plugins/line-numbers/prism-line-numbers.min.css" />
<link rel="stylesheet" type="text/css" href="https://cdnjs.cloudflare.com/ajax/libs/prism/1.16.0/themes/prism-okaidia.css" />
<script src="https://cdnjs.cloudflare.com/ajax/libs/prism/1.16.0/components/prism-csharp.min.js"></script>
<script src="https://cdnjs.cloudflare.com/ajax/libs/prism/1.16.0/components/prism-css.min.js"></script>
<script src="https://cdnjs.cloudflare.com/ajax/libs/prism/1.16.0/components/prism-clike.min.js"></script>
<script src="https://cdnjs.cloudflare.com/ajax/libs/prism/1.16.0/components/prism-javascript.min.js"></script>
<script src="https://cdnjs.cloudflare.com/ajax/libs/prism/1.16.0/components/prism-markdown.min.js"></script>
Try putting it after them in the footer code injection area.
PS. You’ve put 0.1em for the size, I assume you don’t want it that small :sweat_smile:
It worked. Thanks a lot David. Thanks. :slightly_smiling_face:
