I am running into an odd issue. I deployed ghost with docker compose.
newr7:
image: ghost:alpine
container_name: "newr7"
restart: unless-stopped
security_opt:
- no-new-privileges:true
environment:
url: https://newr7.andyc.info
database__client: mysql
database__connection__host: newr7_db
database__connection__password: XXXXXXXXXXXXXXXXXXXXXXXX
database__connection__user: root
mail__from: donotreply@r7acrounited.com
depends_on:
- newr7_db
volumes:
- "/home/newr7/html/:/var/lib/ghost/content:rw"
When I changed the url to the new domain name the site works great. But the /ghost/ admin page doesn’t work. Here are the errors I am seeing in the browser.
[2026-03-19 03:04:56] ERROR "GET /ghost/api/admin/users/me/?include=roles" 403 6ms
Authorization failed
"Unable to determine the authenticated user or integration. Check that cookies are being passed through if using session authentication."
and
Error ID:
818d5b80-2340-11f1-a53e-ab2b0f47c02f
NoPermissionError: Authorization failed
at authorizeAdminApi (/var/lib/ghost/versions/6.22.0/core/server/services/auth/authorize.js:33:25)
at Layer.handle [as handle_request] (/var/lib/ghost/versions/6.22.0/node_modules/express/lib/router/layer.js:95:5)
at next (/var/lib/ghost/versions/6.22.0/node_modules/express/lib/router/route.js:149:13)
at authenticate (/var/lib/ghost/versions/6.22.0/core/server/services/auth/session/middleware.js:48:28)
Has anyone successfully change the URL without issue?
