Hello,
I’m having a issue using a channel. I’ve setup my routes as follows:
routes:
/painting/:
controllers: channel
filter: tag:[painting]
template: index
collections:
permalink: /oeuvre/{year}/{primary_tag}/{slug}/
template: index
taxonomies:
tag: /works/{slug}/
author: /author/{slug}/
and have the following template for index:
(this template is from the edge theme)
{{!< default}}
<div class="content-area">
<main class="site-main container">
<div class="post-feed">
<div class="grid-item grid-sizer"></div>
{{#foreach posts}}
{{> "loop"}}
{{/foreach}}
</div>
{{pagination}}
</main>
</div>
Here you can see the results which is an error message about pagination not available. I used the stock edge them index.hbs as noted should be possible on this tutorial
https://kyleparkercunningham.com/painting/
But you can see that the posts to appear when you go to my taxonomy listing for the tag painting:
So ghost is seeing them one way but not another.
What am I doing wrong? Might it be the template or my routes?
Thank you in advance,
Kyle
