Continuous deployment in AWS environment
I have installed a Ghost blog in AWS EC2. Gatsby is deployed to S3 bucket. Question is; how can I get the S3 to automatically update when new content is added? I tried to search the web with slim results.
http://18.220.22.226/
http://miika-rgf-ghost.s3-website-us-west-2.amazonaws.com/
Ghost has support for outgoing webhooks. You can use them to trigger your build system to rebuild and upload your gatsby site to S3. The Netlify integration is a good place to start:
Thank you for your reply. I went through the Netlify instructions, but I would like to keep my whole project inside AWS products, ie deploy the site in AWS as well.
I can’t give you an exact list of steps, because I don’t know what your build pipeline looks like :wink: I pointed you to the Netlify integration because it gives you a starting place to integrate with S3. In the end, the webhook you add to ghost should trigger a new build of your site and upload it to S3
After playing with the pipeline for two days it seems that going with Netlify at this point might be the best option.
