The html code that I pass in the html parameter may have markup similar to the following:
<pre> <code class="language-py">
#!/usr/bin/env python
import cgitb
cgitb.enable()
print("Content-Type: text/html;charset=utf-8")
print"Content-type:text/html\r\n\r\n"
print '<html>'
print '<head>'
print '<title> Hello Word </title>'
print '</head>'
print '<body>'
print '<h2>Hello Word </h2>'
print '</body>'
print '</html>'
</code></pre>
<pre><code class="language-php">
<?php phpinfo(); ?>
</code></pre>
<IfModule mod_alias.c>
<IfModule mod_cgi.c>
Define ENABLE_USR_LIB_CGI_BIN
</IfModule>
<IfModule mod_cgid.c>
</IfModule>
<IfDefine ENABLE_USR_LIB_CGI_BIN>
#ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
#<Directory "/usr/lib/cgi-bin">
# AllowOverride None
# Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
# Require all granted
#</Directory>
## cgi-bin config
ScriptAlias /cgi-bin/ /var/www/cgi-bin/
<Directory "/var/www/cgi-bin/">
AllowOverride None
Options +ExecCGI
</Directory>
</IfDefine>
</IfModule>
After creating the post, using the API, the result is the following:
import cgitb
cgitb.enable()
print ''
print ''
print ''
print ''
print ''
print 'Hello Word '
print ''
print ''
#ScriptAlias /cgi-bin//usr/lib/cgi-bin/#
## cgi-bin config
ScriptAlias /cgi-bin//var/www/cgi-bin/
AllowOverride None
Options +ExecCGI
How can I solve this problem? Thank you
