zce
November 13, 2018, 2:24am
1
Feature request
Consider adding a custom helper feature?
like this
├── /assets
| └── /css
| ├── screen.css
| ├── /fonts
| ├── /images
| ├── /js
+├── /helpers
+| ├── helper1.js
+| └── helper2.js
├── default.hbs
├── index.hbs [required]
└── post.hbs [required]
└── package.json [required]
or
├── /assets
| └── /css
| ├── screen.css
| ├── /fonts
| ├── /images
| ├── /js
├── default.hbs
+├── functions.js
In this way, we can add more advanced features to the theme more easily.
If there is no problem, I can contribute the pr code.
It’s easy to add custom helpers with Ghost-App module.
Use npm install ghost-app.
Guide has been removed, but you find it here:
https://web.archive.org/web/20181006220559/https://github.com/TryGhost/Ghost/wiki/Apps-Getting-Started-for-Ghost-Devs
And a example here:
This tutorial is also useful:
zce
November 20, 2018, 8:10am
3
I know this method, but I think it would be better to put these helpers in the theme.
I added my vote to this but wanted to add a comment as well.
I was hoping to suppress pagination when there is only one page, e.g. for featured posts.
The if helper won’t work because pages is always at least 1 (if nothing featured I suppress the whole section). has doesn’t help here either.
I would add something like this - if statement - Check for a value equals to in Ember Handlebar If block helper - Stack Overflow .
Kevin
April 5, 2019, 6:12pm
5
@cmckulka how to suppress pagination will depend on how you are rendering pagination but if you’re talking about the code inside pagination.hbs have you tried using the {{has}} helper ? Eg: {{#has any="prev, next"}}...pagination...{{/has}}
There shouldn’t be any need for custom helpers for what you are trying to do. If the {{has}} helper doesn’t work please open a new topic with more details about your template structure and exactly what you are trying to achieve.
Thanks, I’ll try that. I didn’t realize that {{#has any="prev, next"}} would work.
Would still love to add custom helpers though!!
Thanks very much for the quick response!!
I would like to add my vote to this. Something as simple as an eq helper would make theme development much easier.
xtabbas
September 12, 2021, 1:25pm
9
Here is a guide I wrote on similar topic, if anyone needs it.
