I’m using the default Casper theme as a base for a custom theme. I’m configuring the secondary nav with the conditional in the navigation.hbs file:
{{#if isSecondary}}
<ul class="social-nav-list" role="menu">
{{#foreach navigation}}
<li class="nav-{{slug}}"><a href="{{url}}">{{slug}}</a></li>
{{/foreach}}
</ul>
{{else}}
<ul class="nav" role="menu">
<li class="{{link_class for=(url) class=(concat "nav-" slug)}}" role="menuitem"><a href="{{url absolute="true"}}">{{label}}</a></li>
{{/foreach}}
</ul>
{{/if}}
This works as I want it to on every page except the main index. When scrolling down and activating the fixed nav bar (the outer site-nav-main div), the UL of the primary nav is treated as the secondary nav.
All other pages behave as expected and take the primary nav in the else block above. I can confirm by changing the class. All pages are using the same site-header, site-nav, and navigation partials.
Here’s the output from Chrome’s inspector. Top is index.hbs, bottom is author.hbs and all others.
Any ideas?
