Deep Integration Challenges Embedding a Real-Time Morse Code Translator into a Ghost CMS Theme
I run a fairly feature-rich Morse Code translator website that converts plain text into Morse code and decodes Morse back into readable text in real time, using client-side JavaScript along with Web Audio API playback for dots and dashes, copy-to-clipboard utilities, and dynamic UI updates. Recently, I’ve been trying to integrate this entire interactive tool into a Ghost CMS site so it can live alongside blog content, tutorials, and potentially gated member-only features. While simple static embeds work fine, bringing over the full real-time interactivity into a Ghost theme has exposed several technical challenges related to script execution, lifecycle handling, and compatibility with Ghost’s rendering model.
One of the biggest issues I’m encountering is how Ghost handles custom JavaScript inside themes and posts. My Morse Code translator relies heavily on continuous event listeners (like input events), DOM updates, and precise timing functions for audio playback. When I inject the script into a Ghost theme (e.g., via Code Injection or directly in theme files), certain parts of the logic either initialize inconsistently or behave differently across pages. This seems especially noticeable when navigating between pages without a full reload, suggesting potential conflicts with how Ghost handles frontend rendering or cached assets. I’m unsure what the best practice is for initializing complex, stateful scripts in a Ghost environment.
Another challenge is performance and interaction smoothness. The translator is designed to feel instant, updating output as the user types and playing audio sequences with tight timing. However, when combined with a Ghost site that includes theme scripts, analytics, and membership-related JavaScript, I’ve noticed occasional input lag or delayed audio playback. This raises questions about whether I should isolate the tool more aggressively, defer certain scripts, or even move parts of the logic off the main thread. I’d appreciate advice on optimizing performance when embedding highly interactive tools within a CMS-driven site like Ghost.
Membership and access control add another layer of complexity. I’m interested in offering advanced Morse Code features (like longer message playback, downloadable audio, or saved translations) only to logged-in members using Ghost’s built-in membership system. However, I’m not entirely clear on how to securely gate frontend functionality based on membership status without exposing logic that could be bypassed client-side. I’m looking for guidance on how to tie Ghost’s membership data into custom JavaScript features in a secure and maintainable way.
Styling and UI consistency are also proving tricky. My standalone Morse Code site uses custom CSS tailored specifically for the translator interface, but when embedded into a Ghost theme, there are conflicts with global styles, typography, and responsive layouts. While I can override some styles, it becomes messy and hard to maintain, especially across different themes or future updates. I’d like to know if there are recommended ways to encapsulate or scope styles for a complex widget inside a Ghost site without breaking the overall design system.
Finally, I’m trying to decide whether embedding the Morse Code translator directly into Ghost is the right architectural choice at all. An alternative would be to host the tool separately and embed it via iframe or link out to it, but that introduces trade-offs in SEO, analytics tracking, and user experience continuity. I’d really appreciate insights from others who have integrated interactive web applications into Ghost particularly tools that rely on real-time processing and audio on what approaches work best for scalability, maintainability, and long-term performance. Sorry for long post
Interesting project. Is this for fun, or are there some real-world use cases of using morse code in a content driven site?
Regarding to your questions: Despite not being sure if I understand your requirements clearly, it feels like you just need a really optimized theme. Ghost can run with any frontend, including not having at all (see using Ghost as headless CMS). So, all of the client-side performance issues you mention are probably either theme related or Ghost apps (portal.js, sodo search, comments-ui etc.) You can disable all of them, if you don’t need them.
You can create member-only pages/posts and use code injection for those posts to inject your custom scripts. In this way, your JS codes will not be easily fetched without logging in to your site as a member. In some cases you can even use HTML Card to put your JS scripts with conditional visibility.
Yeah, when I read your post, I also asked this question multiple times. At the end Ghost is for publishing content. If you will not need creating any posts after your setup is done, probably you would choose from many other solutions. But if you like the general experience of Ghost, would like to use built-in membership or newsletter functionality, or like the simplicity of it, still it can be a good fit for you.
Right now, the Morse Code translator is partly educational and partly experimental. There’s definitely a hobby/fun aspect to it, but there are also some real-world learning use cases around radio communication, accessibility experiments, and interactive tutorials. That’s why I was interested in combining it with a content-focused platform like Ghost the idea was to pair articles, lessons, and member content with an interactive tool in the same ecosystem rather than treating them as completely separate experiences.
Your point about Ghost essentially being “just the frontend” unless used headlessly is especially useful. I hadn’t fully considered how much of the performance behavior could actually be coming from theme-level scripts or bundled features like Portal, search, or comments rather than Ghost itself. I’ll experiment with disabling unnecessary client-side features and isolating the translator more carefully on specific pages. The suggestion about member-only posts plus conditional code injection is also interesting, especially for lightweight gating of premium features without building a full custom auth system from scratch.
