Docker: Deploying Production Instance
  • What’s your URL? Not currently deployed.
  • What version of Ghost are you using? 3.1
And
  • How was Ghost installed and configured? Docker (not yet working)
  • What Node version, database, OS & browser are you using? MySQL, Manjaro Linux, Firefox generally.
  • What errors or information do you see in the console? The launch of MySQL is simply restarting over and over again based on default docker yaml provided here: https://hub.docker.com/_/ghost/ - full yaml below.
  • What steps could someone else take to reproduce the issue you’re having? I simply copied the available yaml and tried launching. After various attempts and failures I tried simply spinning up MySQL docker (from yaml, running “docker compose up -d db”) and here’s what I see:
488c3e111781 mysql:8.0 “docker-entrypoint.s…” 17 hours ago Restarting (1) 37 seconds ago ghost-db-1
It’s been in a restart cycle for 30 minutes about.
Here is my full yaml - obviously “example” will be changed once I can successfully get this up and running.
FWIW I did get the developer version up and running with the provided docker command:
$ docker run -d --name some-ghost -e NODE_ENV=development -e url=http://[IP]:3001 -p 3001:2368 ghost
version: '3.1'
services:
  ghost:
    image: ghost:5-alpine
    restart: always
    ports:
      - 3001:2368
    environment:
      # see https://ghost.org/docs/config/#configuration-options
      database__client: mysql
      database__connection__user: root
      database__connection__password: example
      # this url value is just an example, and is likely wrong for your environment!
      url: https://dysfunctionalreading.khaos-monkey.com/
      # contrary to the default mentioned in the linked documentation, this image defaults to NODE_ENV=production (so development mode needs to be explicitly specified if desired)
      #NODE_ENV: development
    volumes:
      - ghost:/var/lib/ghost/content
  db:
    image: mysql:8.0
    restart: always
    environment:
      MYSQL_ROOT_PASSWORD: example
    volumes:
      - db:/var/lib/mysql
volumes:
  ghost:
  db:
And FWIW, last couple dozen lines of log for the container:
2024-12-01T16:32:26.422595Z 0 [Warning] [MY-011068] [Server] The syntax '--skip-host-cache' is deprecated and will be removed in a future release. Please use SET GLOBAL host_cache_size=0 instead.
2024-12-01T16:32:26.424105Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.40) starting as process 1
2024-12-01T16:32:26.433987Z 1 [System] [MY-011012] [Server] Starting upgrade of data directory.
2024-12-01T16:32:26.434022Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2024-12-01T16:32:26.479171Z 1 [ERROR] [MY-012224] [InnoDB] Tablespace flags are invalid in datafile: ./ibdata1, Space ID:0, Flags: 21. Please refer to http://dev.mysql.com/doc/refman/8.0/en/innodb-troubleshooting-datadict.html for how to resolve the issue.
2024-12-01T16:32:26.479218Z 1 [ERROR] [MY-012237] [InnoDB] Corrupted page [page id: space=0, page number=0] of datafile './ibdata1' could not be found in the doublewrite buffer.
2024-12-01T16:32:26.479238Z 1 [ERROR] [MY-012930] [InnoDB] Plugin initialization aborted with error Data structure corruption.
2024-12-01T16:32:26.978566Z 1 [ERROR] [MY-011013] [Server] Failed to initialize DD Storage Engine.
2024-12-01T16:32:26.978820Z 0 [ERROR] [MY-010020] [Server] Data Dictionary initialization failed.
2024-12-01T16:32:26.978843Z 0 [ERROR] [MY-010119] [Server] Aborting
2024-12-01T16:32:26.979419Z 0 [System] [MY-010910] [Server] /usr/sbin/mysqld: Shutdown complete (mysqld 8.0.40)  MySQL Community Server - GPL.
2024-12-01 16:33:27+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 8.0.40-1.el9 started.
2024-12-01 16:33:27+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql'
'/var/lib/mysql/mysql.sock' -> '/var/run/mysqld/mysqld.sock'
2024-12-01T16:33:28.061427Z 0 [Warning] [MY-011068] [Server] The syntax '--skip-host-cache' is deprecated and will be removed in a future release. Please use SET GLOBAL host_cache_size=0 instead.
2024-12-01T16:33:28.063015Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.40) starting as process 1
2024-12-01T16:33:28.073049Z 1 [System] [MY-011012] [Server] Starting upgrade of data directory.
2024-12-01T16:33:28.073085Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2024-12-01T16:33:28.117684Z 1 [ERROR] [MY-012224] [InnoDB] Tablespace flags are invalid in datafile: ./ibdata1, Space ID:0, Flags: 21. Please refer to http://dev.mysql.com/doc/refman/8.0/en/innodb-troubleshooting-datadict.html for how to resolve the issue.
2024-12-01T16:33:28.117740Z 1 [ERROR] [MY-012237] [InnoDB] Corrupted page [page id: space=0, page number=0] of datafile './ibdata1' could not be found in the doublewrite buffer.
2024-12-01T16:33:28.117766Z 1 [ERROR] [MY-012930] [InnoDB] Plugin initialization aborted with error Data structure corruption.
2024-12-01T16:33:28.617135Z 1 [ERROR] [MY-011013] [Server] Failed to initialize DD Storage Engine.
2024-12-01T16:33:28.617410Z 0 [ERROR] [MY-010020] [Server] Data Dictionary initialization failed.
2024-12-01T16:33:28.617432Z 0 [ERROR] [MY-010119] [Server] Aborting
2024-12-01T16:33:28.617979Z 0 [System] [MY-010910] [Server] /usr/sbin/mysqld: Shutdown complete (mysqld 8.0.40)  MySQL Community Server - GPL.
2024-12-01 16:34:29+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 8.0.40-1.el9 started.
2024-12-01 16:34:29+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql'
2024-12-01T16:34:29.711388Z 0 [Warning] [MY-011068] [Server] The syntax '--skip-host-cache' is deprecated and will be removed in a future release. Please use SET GLOBAL host_cache_size=0 instead.
2024-12-01T16:34:29.712900Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.40) starting as process 1
2024-12-01T16:34:29.845461Z 1 [System] [MY-011012] [Server] Starting upgrade of data directory.
2024-12-01T16:34:29.845496Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2024-12-01T16:34:29.889647Z 1 [ERROR] [MY-012224] [InnoDB] Tablespace flags are invalid in datafile: ./ibdata1, Space ID:0, Flags: 21. Please refer to http://dev.mysql.com/doc/refman/8.0/en/innodb-troubleshooting-datadict.html for how to resolve the issue.
2024-12-01T16:34:29.889696Z 1 [ERROR] [MY-012237] [InnoDB] Corrupted page [page id: space=0, page number=0] of datafile './ibdata1' could not be found in the doublewrite buffer.
2024-12-01T16:34:29.889722Z 1 [ERROR] [MY-012930] [InnoDB] Plugin initialization aborted with error Data structure corruption.
2024-12-01T16:34:30.389145Z 1 [ERROR] [MY-011013] [Server] Failed to initialize DD Storage Engine.
2024-12-01T16:34:30.389530Z 0 [ERROR] [MY-010020] [Server] Data Dictionary initialization failed.
2024-12-01T16:34:30.389555Z 0 [ERROR] [MY-010119] [Server] Aborting
2024-12-01T16:34:30.390136Z 0 [System] [MY-010910] [Server] /usr/sbin/mysqld: Shutdown complete (mysqld 8.0.40)  MySQL Community Server - GPL.
2024-12-01 16:35:30+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 8.0.40-1.el9 started.
2024-12-01 16:35:30+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql'
2024-12-01T16:35:31.458166Z 0 [Warning] [MY-011068] [Server] The syntax '--skip-host-cache' is deprecated and will be removed in a future release. Please use SET GLOBAL host_cache_size=0 instead.
2024-12-01T16:35:31.459650Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.40) starting as process 1
2024-12-01T16:35:31.469327Z 1 [System] [MY-011012] [Server] Starting upgrade of data directory.
2024-12-01T16:35:31.469366Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2024-12-01T16:35:31.512195Z 1 [ERROR] [MY-012224] [InnoDB] Tablespace flags are invalid in datafile: ./ibdata1, Space ID:0, Flags: 21. Please refer to http://dev.mysql.com/doc/refman/8.0/en/innodb-troubleshooting-datadict.html for how to resolve the issue.
2024-12-01T16:35:31.512241Z 1 [ERROR] [MY-012237] [InnoDB] Corrupted page [page id: space=0, page number=0] of datafile './ibdata1' could not be found in the doublewrite buffer.
2024-12-01T16:35:31.512267Z 1 [ERROR] [MY-012930] [InnoDB] Plugin initialization aborted with error Data structure corruption.
2024-12-01T16:35:32.011752Z 1 [ERROR] [MY-011013] [Server] Failed to initialize DD Storage Engine.
2024-12-01T16:35:32.012142Z 0 [ERROR] [MY-010020] [Server] Data Dictionary initialization failed.
2024-12-01T16:35:32.012184Z 0 [ERROR] [MY-010119] [Server] Aborting
2024-12-01T16:35:32.012909Z 0 [System] [MY-010910] [Server] /usr/sbin/mysqld: Shutdown complete (mysqld 8.0.40)  MySQL Community Server - GPL.
2024-12-01 16:36:32+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 8.0.40-1.el9 started.
2024-12-01 16:36:32+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql'
2024-12-01T16:36:33.055808Z 0 [Warning] [MY-011068] [Server] The syntax '--skip-host-cache' is deprecated and will be removed in a future release. Please use SET GLOBAL host_cache_size=0 instead.
2024-12-01T16:36:33.057317Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.40) starting as process 1
2024-12-01T16:36:33.067256Z 1 [System] [MY-011012] [Server] Starting upgrade of data directory.
2024-12-01T16:36:33.067291Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2024-12-01T16:36:33.111778Z 1 [ERROR] [MY-012224] [InnoDB] Tablespace flags are invalid in datafile: ./ibdata1, Space ID:0, Flags: 21. Please refer to http://dev.mysql.com/doc/refman/8.0/en/innodb-troubleshooting-datadict.html for how to resolve the issue.
2024-12-01T16:36:33.111823Z 1 [ERROR] [MY-012237] [InnoDB] Corrupted page [page id: space=0, page number=0] of datafile './ibdata1' could not be found in the doublewrite buffer.
2024-12-01T16:36:33.111844Z 1 [ERROR] [MY-012930] [InnoDB] Plugin initialization aborted with error Data structure corruption.
2024-12-01T16:36:33.611203Z 1 [ERROR] [MY-011013] [Server] Failed to initialize DD Storage Engine.
2024-12-01T16:36:33.611460Z 0 [ERROR] [MY-010020] [Server] Data Dictionary initialization failed.
2024-12-01T16:36:33.611482Z 0 [ERROR] [MY-010119] [Server] Aborting
2024-12-01T16:36:33.612043Z 0 [System] [MY-010910] [Server] /usr/sbin/mysqld: Shutdown complete (mysqld 8.0.40)  MySQL Community Server - GPL.
2024-12-01 16:37:33+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 8.0.40-1.el9 started.
2024-12-01 16:37:34+00:00 [Note] [Entrypoint]: Switching to dedicated user 'mysql'
2024-12-01 16:37:34+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 8.0.40-1.el9 started.
2024-12-01T16:37:34.660452Z 0 [Warning] [MY-011068] [Server] The syntax '--skip-host-cache' is deprecated and will be removed in a future release. Please use SET GLOBAL host_cache_size=0 instead.
2024-12-01T16:37:34.661938Z 0 [System] [MY-010116] [Server] /usr/sbin/mysqld (mysqld 8.0.40) starting as process 1
2024-12-01T16:37:34.671841Z 1 [System] [MY-011012] [Server] Starting upgrade of data directory.
2024-12-01T16:37:34.671876Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
2024-12-01T16:37:34.716765Z 1 [ERROR] [MY-012224] [InnoDB] Tablespace flags are invalid in datafile: ./ibdata1, Space ID:0, Flags: 21. Please refer to http://dev.mysql.com/doc/refman/8.0/en/innodb-troubleshooting-datadict.html for how to resolve the issue.
2024-12-01T16:37:34.716813Z 1 [ERROR] [MY-012237] [InnoDB] Corrupted page [page id: space=0, page number=0] of datafile './ibdata1' could not be found in the doublewrite buffer.
2024-12-01T16:37:34.716839Z 1 [ERROR] [MY-012930] [InnoDB] Plugin initialization aborted with error Data structure corruption.
2024-12-01T16:37:35.216285Z 1 [ERROR] [MY-011013] [Server] Failed to initialize DD Storage Engine.
2024-12-01T16:37:35.216581Z 0 [ERROR] [MY-010020] [Server] Data Dictionary initialization failed.
2024-12-01T16:37:35.216609Z 0 [ERROR] [MY-010119] [Server] Aborting
2024-12-01T16:37:35.217182Z 0 [System] [MY-010910] [Server] /usr/sbin/mysqld: Shutdown complete (mysqld 8.0.40)  MySQL Community Server - GPL.
Try this docker compose file…
  1. you can use image: ghost:latest on arm64 as well
  2. Map /content to your local file system to store images etc, create a folder /content in the directory where you keep docker-compose.yml
  3. First docker compose pull and then docker compose up to get the logfile in console and see Ghost launching. Then you can kill it with ctrl-C and docker compose up -d to deamonize
  4. e-mail settings included, STARTTLS on 587 starts unencrypted and upgrades, thus mail__options__secure: false
services:
  ghost:
    image: ghost:latest
    restart: always
    ports:
      -  3001:2368
    environment:
      database__connection__password: dbRootPass12345
      url: https://example.com
      mail__options__auth__pass: smtpPassword
      mail__options__auth__user: smtpUser
      mail__options__host: smtp.example.com
      mail__options__port: 587
      mail__options__service: smtpService
      mail__transport: SMTP
      mail__from: sender@example.com
    links:
      -  db
    volumes:
      -  /home/user/dockerghost/content:/var/lib/ghost/content
    depends_on:
      -  db
  db:
    image: arm64v8/mysql:8
    restart: always
    environment:
      MYSQL_ROOT_PASSWORD: dbRootPass12345
      MYSQL_DATABASE: ghost
      MYSQL_USER: ghost
      MYSQL_PASSWORD: dbGhostPass12345
    volumes:
      - mysql-data:/var/lib/mysql
volumes:
  mysql-data:
I was able to resolve this by purging the container directory and just starting from scratch. I’m not sure what the hiccup was but it’s resolved. Thanks!
