Embedding an iframe in London's theme homepage
Hi, I bet this is a simple question for the right people…
The London theme’s homepage leaves a big space for one sentence at the top. I want to add an iframe with a music player underneath the sentence since there is enough space for both.
I have the iframe working on the About page since it’s easy to insert the HTML there, but I don’t know where to add it for the iframe to appear in that location of the homepage. Any help is appreciated!
Hi! In London, that sentence on the homepage is your site description, rendered inside <header class="page-head"> in index.hbs. The easiest way to put your player right under it — without editing the theme, so it survives theme updates — is Code Injection:
Settings → Code injection → Site footer:
<script>
  (function () {
    var head = document.querySelector('.home-template .page-head');
    if (!head) return;
    var player = document.createElement('div');
    player.className = 'home-player';
    player.innerHTML = 'PASTE YOUR IFRAME CODE HERE';
    head.appendChild(player);
</script>
Site header (a bit of spacing and keep it responsive):
<style>
  .home-player { margin-top: 24px; }
  .home-player iframe { max-width: 100%; }
</style>
Paste your iframe between the quotes. If it contains single quotes, swap them for double quotes. It only shows on the homepage, and only when the site description is set — London hides that header when the description is empty.
If you’d rather edit the theme: download it in Settings → Design, add the iframe in index.hbs right after <h2 class="page-head-title">…</h2>, zip it and upload it again. Just remember a future London update would overwrite that change.
@Adrian_Papasergio Yes, your code solved this. Thank you very much!
Happy to read that! Good Sunday!
