Error upload images
I just migrated from version 0.11.x 1.x and 2.X, everything worked without problems.
But when I’m writing a new entry and uploading a photo, it sends me an error that can not access it.
Viewing the log I found this error, I do not know what permissions should go in the path ./content/images, so I can write in it.
ERROR [2018-11-20 23:28:41] “POST /ghost/api/v2/admin/uploads/” 500 319ms
Nov 21 01:28:41 host.mx node[10736]:
Nov 21 01:28:41 host.mx node[10736]: NAME: InternalServerError
Nov 21 01:28:41 host.mx node[10736]: CODE: EACCES
Nov 21 01:28:41 host.mx node[10736]: MESSAGE: EACCES: permission denied, open ‘/var/www/ghost/content/images/2018/11/Captura-de-pantalla-2018-11-20-a-la-s–5.21.11-p.m…png’
Nov 21 01:28:41 host.mx node[10736]: level:normal
Nov 21 01:28:41 host.mx node[10736]: empty
Nov 21 01:28:41 host.mx node[10736]: ERROR DETAILS:
Nov 21 01:28:41 host.mx node[10736]: InternalServerError: EACCES: permission denied, open ‘/var/www/ghost/content/images/2018/11/Captura-de-pantalla-2018-11-20-a-la-s–5.21.11-p.m…png’
Nov 21 01:28:41 host.mx node[10736]: at new GhostError (/var/www/ghost/versions/2.6.1/core/server/lib/common/errors.js:10:26)
Nov 21 01:28:41 host.mx node[10736]: at _private.prepareError (/var/www/ghost/versions/2.6.1/core/server/web/shared/middlewares/error-handler.js:42:19)
Nov 21 01:28:41 host.mx node[10736]: at Layer.handle_error (/var/www/ghost/versions/2.6.1/node_modules/express/lib/router/layer.js:71:5)
Nov 21 01:28:41 host.mx node[10736]: at trim_prefix (/var/www/ghost/versions/2.6.1/node_modules/express/lib/router/index.js:315:13)
Nov 21 01:28:41 host.mx node[10736]: at /var/www/ghost/versions/2.6.1/node_modules/express/lib/router/index.js:284:7
Nov 21 01:28:41 host.mx node[10736]: at Function.process_params (/var/www/ghost/versions/2.6.1/node_modules/express/lib/router/index.js:335:12)
Nov 21 01:28:41 host.mx node[10736]: at next (/var/www/ghost/versions/2.6.1/node_modules/express/lib/router/index.js:275:10)
Nov 21 01:28:41 host.mx node[10736]: at Layer.handle_error (/var/www/ghost/versions/2.6.1/node_modules/express/lib/router/layer.js:67:12)
Nov 21 01:28:41 host.mx node[10736]: at /var/www/ghost/versions/2.6.1/node_modules/express/lib/router/index.js:635:15
Nov 21 01:28:41 host.mx node[10736]: at next (/var/www/ghost/versions/2.6.1/node_modules/express/lib/router/index.js:260:14)
Nov 21 01:28:41 host.mx node[10736]: at next (/var/www/ghost/versions/2.6.1/node_modules/express/lib/router/route.js:127:14)
Nov 21 01:28:41 host.mx node[10736]: at apiImpl.then.catch (/var/www/ghost/versions/2.6.1/core/server/api/shared/http.js:59:17)
Nov 21 01:28:41 host.mx node[10736]: Error: EACCES: permission denied, open ‘/var/www/ghost/content/images/2018/11/Captura-de-pantalla-2018-11-20-a-la-s–5.21.11-p.m…png’
It sounds like your directory permissions are messed up! Can you run ghost doctor to hopefully fix the issue?
