Failed to log in, please try again
Let me know if you managed to solve the problem.
@AnimaVillis and @jannis
Please, I have a little issue here, after accessing /var/www/ghost$ I used this command: mysql -u root -p and then I tried to use enter my password I got this error again ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
Please what am I doing wrong here? thanks
Again, depends on how you set up your MySQL server.
Potentially you set up MySQL with socket authentication. Then you could just run sudo mysql.
If that also fails, you’d probably need to recover access.
hm… read this;
It could help, but for sure give information about Your stack.
Okay, thanks for sharing, I will try it out.
Okay, I will check it out, thanks :pray:
Hey @cassyblaise , did you solved this?
i m facing the same issue, and i m curious
Hey @rotello, there were multiple different errors and issues in the very long trouble-shooting thread you’re bumping from 11 months ago. Please start a fresh thread and start by explaining what your setup is and what specific error message(s) you’re seeing.
Thanks!
