I am using Local installation Latest Ghost V3.1.1.
OS is Windows 10
This is my routes.yaml file
routes:
collections:
/example/:
permalink: /example/{slug}/
template: example
filter: tag:example
data: tag.example
permalink: /{slug}/
template: index
taxonomies:
tag: /tag/{slug}/
author: /author/{slug}/
Using this routes.yaml file posts with the tag examle being listed at http://localhost:2368/example/` using the example.hbs template file. At this point everything is OK and as intended.
But my problem is when I visit a post from this custom collection the post is rendered using the default post.hbs template.
I want to use a custom template file for the full post of this custom collection.
I know there is a work around I can define a custom template by prefixing custom to that template file name like this custom-example.hbs But in this case I have to select it each time I create a new post for the custom collection.
I was wandering that may be there is a easy way to define it in routes.yaml file for once to used by all post in a collection.
EDIT Another question: Collection do not showing the meta title of the tag from the data instead it only showing the site tile similar to home. It should show Development - Example But showing Development (Page 1) Please see the image.
