Hello,
I was wondering if there was an option so that Excerpts are filled automatically.
Right now, i have to fill manually all excerpts, I’d rather Ghost just take the 300 first character of my publication by default and use them rather than doing it myself.
It seems it’s supposed to work that way by default, so I might be missing something?
It sounds like your theme is checking for and using {{custom_excerpt}}, which will not generate an excerpt if one is not set, instead of {{excerpt}}, which uses the custom_excerpt if it exists, or generates an excerpt from the start of the post if it doesn’t.
Ah, but it removes the automated filling of Excerpt when non is provided
That would be a nice feature to have, to be able to set Excerpt visibility somewhere in the console (Labs?). Not sure it’s do-able in the API : is that something that can be added in the feature-request ?
