I spent way too long working out the answer to this, so I thought I’d share.
How do I change the tags page (taxonomy) to exclude posts that are also tagged with something else.
I’m using a #archive tag to hide posts from lists (because they’re date-related), but I still want them to be accessible on the site.
I can’t use filters in the route as it’s a taxonomy.
The posts are displayed using a #foreach loop that uses an automatically generated collection.
Original tag.hbs
{{!< default}}
<div class="gh-outer">
<main class="site-main gh-inner">
{{#tag}}
<div class="term">
<h1 class="term-name">{{name}}</h1>
{{#if description}}
<p class="term-description">{{description}}</p>
{{/if}}
</div>
{{/tag}}
<div class="post-feed gh-feed">
{{#foreach posts order="featured desc, updated_at desc, created_at desc" }}
{{> "loop"}}
{{/foreach}}
</div>
</main>
</div>
You need to put the #foreach
loop inside a #get
helper where you apply the filters you want.
In order to apply this to a tags page, you need to access the tag slug from the page, which is not available to the #foreach
loop as the #tag
helper is closed before the code gets there. So you need to move the {{/tag}}
closing tag below the #get
helper, too.
Final code:
{{!< default}}
{{#tag}}
<div class="term">
{{#if description}}
{{/if}}
</div>
{{#get "posts" limit="1000" filter="tag:{{slug}}+tag:-hash-archive" order="featured desc, updated_at desc, created_at desc" as |related|}}
{{#if related}}
{{#foreach related}}
{{> "loop"}}
{{/foreach}}
{{/if}}
{{/get}}
</div>
{{/tag}}
</main>
</div>
I’ve been struggling with this too, approaching it through the routes file since I bought a brand new shiny theme, and don’t want to gut it.
There really should be a simple way to archive posts.
Edit: Still haven’t figured out how to do this.
