Filtering with not operator not working for some tag properties
I’m trying to filter tags in the template via the {{#get }} syntax. I can use the - operator on the tag name and slug, but not the description, meta_title or meta_description properties. The output seems to be as if I had set the filter to -null, rather than, for example, -test.
Is this observed behaviour by design or is it bug?
Thanks.
Our filtering behaviour was recently overhauled, and is about to be launched via our new V2 API. We’re actively working on wrapping that up this week. I’ll try to remember to post back here when it’s done.
OK Hannah. Thanks for the quick reply. I’ll revisit this issue at the end of the week and hopefully all will be well.
After today’s update, the tag filtering seems to be doing what I want it to do now. Thanks.
