Hi, I don’t think this is something that’s that high priority as it’s probably an edge case but it seems that using an author slug of length 1 breaks the Ghost Admin filter by author functionality (and by extension anything that uses the same API endpoint). If I change the author slug a slug of length 2 or higher, I’m able to filter by that author’s slug again.
Here’s an entry from the error log;
"name":"Log",
"hostname":"planamag",
"pid":19192,
"level":50,
"req":{
"meta":{
"requestId":"b05edaa6-c174-449f-9e0c-9dce58f4d5a2",
"userId":"5b84e0c67e388e3cf5be748b"
"url":"/posts/?limit=30&page=1&filter=status%3A%5Bdraft%2Cscheduled%2Cpublished%5D%2Bauthors%3Aq",
"method":"GET",
"originalUrl":"/ghost/api/v3/admin/posts/?limit=30&page=1&filter=status%3A%5Bdraft%2Cscheduled%2Cpublished%5D%2Bauthors%3Aq",
"params":{},
"headers":{
"x-forwarded-proto":"https",
"x-real-ip":"44.224.2.133",
"host":"planamag.com",
"x-nginx-proxy":"true",
"connection":"close",
"accept":"application/json, text/javascript, */*; q=0.01",
"dnt":"1",
"x-requested-with":"XMLHttpRequest",
"x-ghost-version":"3.26",
"app-pragma":"no-cache",
"user-agent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_14_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.89 Safari/537.36",
"content-type":"application/json; charset=UTF-8",
"sec-fetch-site":"same-origin",
"sec-fetch-mode":"cors",
"sec-fetch-dest":"empty",
"referer":"https://planamag.com/ghost/",
"accept-encoding":"gzip, deflate, br",
"accept-language":"en-US,en;q=0.9",
"cookie":"**REDACTED**"
"query":{
"limit":"30",
"page":"1",
"filter":"status:[draft,scheduled,published]+authors:q"}},
"res":{
"_headers":{
"x-powered-by":"Express",
"cache-control":"no-cache, private, no-store, must-revalidate, max-stale=0, post-check=0, pre-check=0",
"content-type":"application/json; charset=utf-8",
"content-length":"232",
"etag":"W/\"e8-rdwJ52UL4TPbqmP33hk0hlsoxuA\"",
"vary":"Accept-Encoding"
"statusCode":400,
"responseTime":"25ms"
"err":{
"id":"608ad8b0-cd63-11ea-82f0-47fd86c6e32c",
"domain":"https://planamag.com",
"code":null,
"name":"BadRequestError",
"statusCode":400,
"level":"normal",
"message":"Error parsing filter",
"stack":"BadRequestError: Error parsing filter
at new BadRequestError (/var/www/ghost/versions/3.26.1/node_modules/ghost-ignition/lib/errors/index.js:113:23)
at Child.applyDefaultAndCustomFilters (/var/www/ghost/versions/3.26.1/core/server/models/plugins/filter.js:104:23)
at Function.findPage (/var/www/ghost/versions/3.26.1/core/server/models/base/index.js:896:24)
at Object.query (/var/www/ghost/versions/3.26.1/core/server/api/canary/posts.js:40:32)
at Object.query (/var/www/ghost/versions/3.26.1/core/server/api/shared/pipeline.js:156:24)
at Promise.resolve.then.then.then.then (/var/www/ghost/versions/3.26.1/core/server/api/shared/pipeline.js:243:35)
at tryCatcher (/var/www/ghost/versions/3.26.1/node_modules/bluebird/js/release/util.js:16:23)
at Promise._settlePromiseFromHandler (/var/www/ghost/versions/3.26.1/node_modules/bluebird/js/release/promise.js:547:31)
at Promise._settlePromise (/var/www/ghost/versions/3.26.1/node_modules/bluebird/js/release/promise.js:604:18)
at Promise._settlePromise0 (/var/www/ghost/versions/3.26.1/node_modules/bluebird/js/release/promise.js:649:10)
at Promise._settlePromises (/var/www/ghost/versions/3.26.1/node_modules/bluebird/js/release/promise.js:729:18)
at _drainQueueStep (/var/www/ghost/versions/3.26.1/node_modules/bluebird/js/release/async.js:93:12)
at _drainQueue (/var/www/ghost/versions/3.26.1/node_modules/bluebird/js/release/async.js:86:9)
at Async._drainQueues (/var/www/ghost/versions/3.26.1/node_modules/bluebird/js/release/async.js:102:5)
at Immediate.Async.drainQueues [as _onImmediate] (/var/www/ghost/versions/3.26.1/node_modules/bluebird/js/release/async.js:15:14)
at runCallback (timers.js:705:18)
at tryOnImmediate (timers.js:676:5)
at processImmediate (timers.js:658:5)
at process.topLevelDomainCallback (domain.js:126:23)\n\nError: Query Error: unrecognized text \"q\" in filter at char 24\n...,published]+authors:q)+type:post\n-----------------------^
at Object.lexer.parseError (/var/www/ghost/versions/3.26.1/node_modules/@nexes/nql-lang/dist/parser.js:711:11)
at Object.next (/var/www/ghost/versions/3.26.1/node_modules/@nexes/nql-lang/dist/parser.js:594:25)
at Object.lex (/var/www/ghost/versions/3.26.1/node_modules/@nexes/nql-lang/dist/parser.js:604:22)
at lex (/var/www/ghost/versions/3.26.1/node_modules/@nexes/nql-lang/dist/parser.js:215:27)
at Parser.parse (/var/www/ghost/versions/3.26.1/node_modules/@nexes/nql-lang/dist/parser.js:228:26)
at Object.exports.parse (/var/www/ghost/versions/3.26.1/node_modules/@nexes/nql-lang/lib/nql.js:18:44)
at Object.api.parse (/var/www/ghost/versions/3.26.1/node_modules/@nexes/nql/lib/nql.js:15:31)
at Object.api.querySQL.qb [as querySQL] (/var/www/ghost/versions/3.26.1/node_modules/@nexes/nql/lib/nql.js:49:44)
at Builder.query (/var/www/ghost/versions/3.26.1/core/server/models/plugins/filter.js:101:24)
at Object.query (/var/www/ghost/versions/3.26.1/node_modules/bookshelf/lib/helpers.js:57:14)
at Child.query (/var/www/ghost/versions/3.26.1/node_modules/bookshelf/lib/model.js:1256:22)
at Child.applyDefaultAndCustomFilters (/var/www/ghost/versions/3.26.1/core/server/models/plugins/filter.js:94:22)
at process.topLevelDomainCallback (domain.js:126:23)"
"msg":"Error parsing filter",
"time":"2020-07-24T04:08:49.347Z",
"v":0
I think the easiest fix is to change the slug to something longer but I thought I’d report this bug anyway.
Ghost-CLI version: 1.14.1
Ghost version: 3.26.1 -
Self-hosted on DigitalOcean droplet (Ubuntu 16.04.5 LTS) -
Node v10.18.1, MySQL v14.14 Distrib 5.7.30, Mac OS 10.14.6, Google Chrome v84.0.4147.89 -
GET https://planamag.com/ghost/api/v3/admin/posts/?limit=30&page=1&filter=status%3A[draft%2Cscheduled%2Cpublished]%2Bauthors%3Aa 400
send @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:917
ajax @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:893
_makeRequest @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:9076
_makeRequest @ ghost.min-0dc4cd8c69609a43c4bf910036dd7f14.js:1782
n @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:2363
request @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:9073
ajax @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:9113
query @ ghost.min-0dc4cd8c69609a43c4bf910036dd7f14.js:6
query @ ghost.min-0dc4cd8c69609a43c4bf910036dd7f14.js:13
(anonymous) @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:8685
b @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:4376
(anonymous) @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:4383
invoke @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:3943
flush @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:3935
flush @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:3946
_end @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:3998
end @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:3959
_run @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:4000
_join @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:3999
join @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:3970
d @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:2794
(anonymous) @ vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:2795
vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:2054 Error while processing route: posts Request was formatted incorrectly. Error: Request was formatted incorrectly.
at e._createCorrectError (https://planamag.com/ghost/assets/vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:9097:41)
at e.handleResponse (https://planamag.com/ghost/assets/vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:9093:205)
at e.handleResponse (https://planamag.com/ghost/assets/ghost.min-0dc4cd8c69609a43c4bf910036dd7f14.js:1791:78)
at e.n [as handleResponse] (https://planamag.com/ghost/assets/vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:2363:9)
at e. (https://planamag.com/ghost/assets/vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:9082:70)
at l (https://planamag.com/ghost/assets/vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:621:118)
at Object.fireWith [as rejectWith] (https://planamag.com/ghost/assets/vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:622:698)
at A (https://planamag.com/ghost/assets/vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:905:468)
at XMLHttpRequest. (https://planamag.com/ghost/assets/vendor.min-9ec0ec4b5d6e604986a7d579c6dd3fbf.js:916:206) -
Set an author’s slug to one character, attempt to filter posts by that author’s slug
