I’m have a server where I initially set up Nginx with a LetsEncrypt SSL before I installed the Ghost CMS. I went ahead and skipped the step where Ghost prompts you to set up Nginx, and now with the following config, I can get the homepage to work, but the following gives me 404s
- everything from the /assets dir
- any other page besides the homepage (admin panel, any subpath under the homepage)
ghost -v
1.11.0
CMS version is 2.31.1
What configuration?
"url": "https://example.com",
"server": {
"port": 2368,
"host": "127.0.0.1"
"database": {
"client": "mysql",
"connection": {
"host": "localhost",
"user": "ghost_user",
"password": "PASSWORD",
"database": "ghost_db"
"mail": {
"transport": "Direct"
"logging": {
"transports": [
"file",
"stdout"
"process": "systemd",
"paths": {
"contentPath": "/var/www/example.com/html/content"
"bootstrap-socket": {
"port": 8000,
"host": "localhost"
Nginx Config:
server {
server_name example.com www.example.com;
location / {
try_files $uri $uri/ =404;
listen [::]:443 ssl ipv6only=on; # managed by Certbot
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/example.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/example.com/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
if ($host = www.example.com) {
} # managed by Certbot
if ($host = example.com) {
listen 80;
listen [::]:80;
return 404; # managed by Certbot
What Port
2368
