I’m trying to install Ghost on a rented VM but the installation keeps failing when trying to setup the ghost mysql user.
- I’m following the instructions here How to install & setup Ghost on Ubuntu 16.04, 18.04, 20.04 or 22.04. The only modification was to install Node.js using the instructions at nodesource/distributions: NodeSource Node.js Binary Distributions (github.com) for Node 18x
- I’ve done a completely fresh install twice now, on completely new Ubuntu 22.04 VMs and had the same problem both times
- I can login the mqsql using the user
rootand the password copied from myconfig.production.json, so I’ve entered the correct mysql password during setup - Listing users and databases in mysql shows the following, which seems to confirm that the setup process hasn’t been able to create a ghost user or database:
| User |
| debian-sys-maint |
| mysql.infoschema |
| mysql.session |
| mysql.sys |
| root |
| Database |
| information_schema |
| mysql |
| performance_schema |
| sys |
- Using
netstat -tln, I confirmed that mysql is listening on port 3306:
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:33060 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN
tcp6 0 0 :::22 :::* LISTEN
tcp6 0 0 :::80 :::* LISTEN
tcp6 0 0 :::443 :::* LISTEN
- Output of ghost setup is:
? Enter your blog URL: https://blog.myurl.com
? Enter your MySQL hostname: localhost
? Enter your MySQL username: root
? Enter your MySQL password (skip to keep current password): [hidden]
? Enter your Ghost database name: myurl_prod
✔ Configuring Ghost
+ sudo chown -R ghost:ghost /var/www/myurl/content
✔ Setting up "ghost" system user
? Do you wish to set up "ghost" mysql user? Yes
✖ Setting up "ghost" mysql user
Nginx configuration already found for this url. Skipping Nginx setup.
ℹ Setting up Nginx [skipped]
Nginx setup task was skipped, skipping SSL setup
ℹ Setting up SSL [skipped]
Systemd service has already been set up. Skipping Systemd setup
ℹ Setting up Systemd [skipped]
+ sudo systemctl is-active ghost_blog-myurl-com
+ sudo systemctl reset-failed ghost_blog-myurl-com
? Do you want to start Ghost? Yes
+ sudo systemctl start ghost_blog-myurl-com
+ sudo systemctl stop ghost_blog-myurl-com
✖ Starting Ghost
One or more errors occurred.
1) ConfigError
Error detected in the production configuration.
Message: connect ECONNREFUSED ::1:3306
Configuration Key(s): database.connection.host / database.connection.port
Current Value(s): localhost / 3306
Help: Ensure that MySQL is installed and reachable. You can always re-run `ghost setup` to try again.
2) GhostError
Message: Ghost was able to start, but errored during boot with: connect ECONNREFUSED ::1:3306
Help: Unknown database error
Suggestion: journalctl -u ghost_blog-myurl-com -n 50
OS: Ubuntu, v22.04.3 LTS
Node Version: v18.17.1
Ghost Version: 5.61.3
Ghost-CLI Version: 1.24.2
Environment: production
Command: 'ghost setup'
- Output of ghost doctor:
✔ Checking system Node.js version - found v18.17.1
✔ Checking logged in user
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking free space
✔ Checking systemd unit file
✔ Checking systemd node version - found v18.17.1
- Contents of my
config.production.json:
"url": "https://blog.myurl.com",
"server": {
"port": 2368,
"host": "127.0.0.1"
"database": {
"client": "mysql",
"connection": {
"host": "localhost",
"port": 3306,
"user": "root",
"password": "mypassword",
"database": "myurl_prod"
"mail": {
"transport": "Direct"
"logging": {
"transports": [
"file",
"stdout"
"process": "systemd",
"paths": {
"contentPath": "/var/www/myurl/content"
"bootstrap-socket": {
"port": 8000,
"host": "localhost"
Any help would be very much appreciated!
