jeff
October 29, 2022, 5:16am
1
npm WARN EBADENGINE Unsupported engine {
npm WARN EBADENGINE package: 'ghost-cli@1.23.1',
npm WARN EBADENGINE required: { node: '^12.22.1 || ^14.17.0 || ^16.13.0' },
npm WARN EBADENGINE current: { node: 'v18.12.0', npm: '8.19.2' }
npm WARN EBADENGINE }
Any news on when ghost-cli will support latest Node stable release?
FYI - v18, was released in April, and Node stable was switched to v18 on 25th Oct.
jeff
October 29, 2022, 5:33am
2
looks like itās in the pipelineā¦
TryGhost:main ā TryGhost:renovate/node-18.x
opened 01:16AM - 25 Oct 22 UTC
[](https://renova⦠tebot.com)
This PR contains the following updates:
| Package | Type | Update | Change |
| [node](https://togithub.com/nodejs/node) | engines | major | [`^14.17.0 \|\| ^16.13.0` -> `^14.17.0 \|\| ^16.13.0 \|\| ^18.0.0`](https://renovatebot.com/diffs/npm/node/v16.18.1/v18.12.1) |
### Release Notes
<details>
<summary>nodejs/node</summary>
### [`v18.12.1`](https://togithub.com/nodejs/node/releases/tag/v18.12.1): 2022-11-04, Version 18.12.1 'Hydrogen' (LTS), @​juanarbol
[Compare Source](https://togithub.com/nodejs/node/compare/v18.12.0...v18.12.1)
This is a security release.
##### Notable changes
The following CVEs are fixed in this release:
- **[CVE-2022-3602](https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-3602)**: X.509 Email Address 4-byte Buffer Overflow (High)
- **[CVE-2022-3786](https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-3786)**: X.509 Email Address Variable Length Buffer Overflow (High)
- **[CVE-2022-43548](https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-43548)**: DNS rebinding in --inspect via invalid octal IP address (Medium)
More detailed information on each of the vulnerabilities can be found in [November 2022 Security Releases](https://nodejs.org/en/blog/vulnerability/november-2022-security-releases/) blog post.
##### Commits
- \[[`39f8a672e3`](https://togithub.com/nodejs/node/commit/39f8a672e3)] - **deps**: update archs files for quictls/openssl-3.0.7+quic [nodejs/node#​45286](https://togithub.com/nodejs/node/pull/45286)
- \[[`80218127c8`](https://togithub.com/nodejs/node/commit/80218127c8)] - **deps**: upgrade openssl sources to quictls/openssl-3.0.7+quic [nodejs/node#​45286](https://togithub.com/nodejs/node/pull/45286)
- \[[`165342beac`](https://togithub.com/nodejs/node/commit/165342beac)] - **inspector**: harden IP address validation again (Tobias NieĆen) [nodejs-private/node-private#​354](https://togithub.com/nodejs-private/node-private/pull/354)
### [`v18.12.0`](https://togithub.com/nodejs/node/releases/tag/v18.12.0): 2022-10-25, Version 18.12.0 'Hydrogen' (LTS), @​ruyadorno and @​RafaelGSS
[Compare Source](https://togithub.com/nodejs/node/compare/v18.11.0...v18.12.0)
##### Notable Changes
This release marks the transition of Node.js 18.x into Long Term Support (LTS)
with the codename 'Hydrogen'. The 18.x release line now moves into "Active LTS"
and will remain so until October 2023. After that time, it will move into
"Maintenance" until end of life in April 2025.
### [`v18.11.0`](https://togithub.com/nodejs/node/releases/tag/v18.11.0): 2022-10-13, Version 18.11.0 (Current), @​danielleadams
[Compare Source](https://togithub.com/nodejs/node/compare/v18.10.0...v18.11.0)
##### watch mode (experimental)
Running in 'watch' mode using `node --watch` restarts the process when an imported file is changed.
Contributed by Moshe Atlow in [#​44366](https://togithub.com/nodejs/node/pull/44366)
##### Other notable changes
- **fs**:
- (SEMVER-MINOR) add `FileHandle.prototype.readLines` (Antoine du Hamel) [#​42590](https://togithub.com/nodejs/node/pull/42590)
- **http**:
- (SEMVER-MINOR) add writeEarlyHints function to ServerResponse (Wing) [#​44180](https://togithub.com/nodejs/node/pull/44180)
- **http2**:
- (SEMVER-MINOR) make early hints generic (Yagiz Nizipli) [#​44820](https://togithub.com/nodejs/node/pull/44820)
- **lib**:
- (SEMVER-MINOR) refactor transferable AbortSignal (flakey5) [#​44048](https://togithub.com/nodejs/node/pull/44048)
- **src**:
- (SEMVER-MINOR) add detailed embedder process initialization API (Anna Henningsen) [#​44121](https://togithub.com/nodejs/node/pull/44121)
- **util**:
- (SEMVER-MINOR) add default value option to parsearg (Manuel Spigolon) [#​44631](https://togithub.com/nodejs/node/pull/44631)
##### Commits
- \[[`27b4b782ce`](https://togithub.com/nodejs/node/commit/27b4b782ce)] - **benchmark**: add vm context global proxy benchmark (Joyee Cheung) [#​44796](https://togithub.com/nodejs/node/pull/44796)
- \[[`4e82521af1`](https://togithub.com/nodejs/node/commit/4e82521af1)] - **bootstrap**: update comments in bootstrap/node.js (Joyee Cheung) [#​44726](https://togithub.com/nodejs/node/pull/44726)
- \[[`725be0ea50`](https://togithub.com/nodejs/node/commit/725be0ea50)] - **buffer**: initialize TextDecoder once on blob.text() (Yagiz Nizipli) [#​44787](https://togithub.com/nodejs/node/pull/44787)
- \[[`653c3b1f62`](https://togithub.com/nodejs/node/commit/653c3b1f62)] - **buffer,lib**: update atob to align wpt's base64.json (Khaidi Chu) [#​43901](https://togithub.com/nodejs/node/pull/43901)
- \[[`37808b3355`](https://togithub.com/nodejs/node/commit/37808b3355)] - **build**: convert V8 test JSON to JUnit XML (Keyhan Vakil) [#​44049](https://togithub.com/nodejs/node/pull/44049)
- \[[`f92871a52b`](https://togithub.com/nodejs/node/commit/f92871a52b)] - **build**: update timezone-update.yml (Alex) [#​44717](https://togithub.com/nodejs/node/pull/44717)
- \[[`f85d3471ee`](https://togithub.com/nodejs/node/commit/f85d3471ee)] - **child_process**: remove lookup of undefined property (Colin Ihrig) [#​44766](https://togithub.com/nodejs/node/pull/44766)
- \[[`2f5f41c315`](https://togithub.com/nodejs/node/commit/2f5f41c315)] - **(SEMVER-MINOR)** **cli**: add `--watch` (Moshe Atlow) [#​44366](https://togithub.com/nodejs/node/pull/44366)
- \[[`7fb9cc70f3`](https://togithub.com/nodejs/node/commit/7fb9cc70f3)] - **cluster**: use inspector utils (Moshe Atlow) [#​44592](https://togithub.com/nodejs/node/pull/44592)
- \[[`99a2c16040`](https://togithub.com/nodejs/node/commit/99a2c16040)] - **crypto**: add causes to applicable webcrypto's OperationError (Filip Skokan) [#​44890](https://togithub.com/nodejs/node/pull/44890)
- \[[`e0fbba0939`](https://togithub.com/nodejs/node/commit/e0fbba0939)] - **crypto**: use EVP_PKEY_CTX_set_dsa_paramgen_q_bits when available (David Benjamin) [#​44561](https://togithub.com/nodejs/node/pull/44561)
- \[[`a90386b0a1`](https://togithub.com/nodejs/node/commit/a90386b0a1)] - **deps**: update undici to 5.11.0 (Node.js GitHub Bot) [#​44929](https://togithub.com/nodejs/node/pull/44929)
- \[[`aa68d40fbf`](https://togithub.com/nodejs/node/commit/aa68d40fbf)] - **deps**: update corepack to 0.14.2 (Node.js GitHub Bot) [#​44775](https://togithub.com/nodejs/node/pull/44775)
- \[[`c892f35815`](https://togithub.com/nodejs/node/commit/c892f35815)] - **deps**: V8: fix debug build (Ben Noordhuis) [#​44392](https://togithub.com/nodejs/node/pull/44392)
- \[[`91514393dc`](https://togithub.com/nodejs/node/commit/91514393dc)] - **dns**: support dns module in the snapshot (Joyee Cheung) [#​44633](https://togithub.com/nodejs/node/pull/44633)
- \[[`ce3cb29319`](https://togithub.com/nodejs/node/commit/ce3cb29319)] - **doc**: add fsPromises.readFile() example (Tierney Cyren) [#​40237](https://togithub.com/nodejs/node/pull/40237)
- \[[`97df9b84a2`](https://togithub.com/nodejs/node/commit/97df9b84a2)] - **doc**: improve building doc for Android (BuShe Pie) [#​44888](https://togithub.com/nodejs/node/pull/44888)
- \[[`8c69da893b`](https://togithub.com/nodejs/node/commit/8c69da893b)] - **doc**: mention `corepack prepare` supports tag or range (Michael Rienstra) [#​44646](https://togithub.com/nodejs/node/pull/44646)
- \[[`842bc64833`](https://togithub.com/nodejs/node/commit/842bc64833)] - **doc**: remove Legacy status from querystring (Rich Trott) [#​44912](https://togithub.com/nodejs/node/pull/44912)
- \[[`ddb5402f5f`](https://togithub.com/nodejs/node/commit/ddb5402f5f)] - **doc**: fix label name in collaborator guide (Rich Trott) [#​44920](https://togithub.com/nodejs/node/pull/44920)
- \[[`d08b024a3d`](https://togithub.com/nodejs/node/commit/d08b024a3d)] - **doc**: fix typo in Node.js 12 changelog (Lorand Horvath) [#​42880](https://togithub.com/nodejs/node/pull/42880)
- \[[`b6b9c427c5`](https://togithub.com/nodejs/node/commit/b6b9c427c5)] - **doc**: move release keys we don't use anymore in README (Rich Trott) [#​44899](https://togithub.com/nodejs/node/pull/44899)
- \[[`e92b074b32`](https://togithub.com/nodejs/node/commit/e92b074b32)] - **doc**: fix grammar in dns docs ([#​44850](https://togithub.com/nodejs/node/issues/44850)) (Colin Ihrig) [#​44850](https://togithub.com/nodejs/node/pull/44850)
- \[[`780144c339`](https://togithub.com/nodejs/node/commit/780144c339)] - **doc**: remove unnecessary leading commas (Colin Ihrig) [#​44854](https://togithub.com/nodejs/node/pull/44854)
- \[[`6ae9bc8fbc`](https://togithub.com/nodejs/node/commit/6ae9bc8fbc)] - **doc**: add extra step for reporter pre-approval (Rafael Gonzaga) [#​44806](https://togithub.com/nodejs/node/pull/44806)
- \[[`ccf31d8bca`](https://togithub.com/nodejs/node/commit/ccf31d8bca)] - **doc**: add anchor link for --preserve-symlinks (Kohei Ueno) [#​44858](https://togithub.com/nodejs/node/pull/44858)
- \[[`7c5c19ee54`](https://togithub.com/nodejs/node/commit/7c5c19ee54)] - **doc**: update node prefix require.cache example (Simone Busoli) [#​44724](https://togithub.com/nodejs/node/pull/44724)
- \[[`2a5bce6318`](https://togithub.com/nodejs/node/commit/2a5bce6318)] - **doc**: include last security release date (Vladimir de Turckheim) [#​44794](https://togithub.com/nodejs/node/pull/44794)
- \[[`4efaf4265c`](https://togithub.com/nodejs/node/commit/4efaf4265c)] - **doc**: remove "currently" and comma splice from child_process.md (Rich Trott) [#​44789](https://togithub.com/nodejs/node/pull/44789)
- \[[`3627616b40`](https://togithub.com/nodejs/node/commit/3627616b40)] - **doc,crypto**: mark experimental algorithms more visually (Filip Skokan) [#​44892](https://togithub.com/nodejs/node/pull/44892)
- \[[`3c653cf23a`](https://togithub.com/nodejs/node/commit/3c653cf23a)] - **doc,crypto**: add missing CFRG curve algorithms to supported lists (Filip Skokan) [#​44876](https://togithub.com/nodejs/node/pull/44876)
- \[[`70f55020d3`](https://togithub.com/nodejs/node/commit/70f55020d3)] - **doc,crypto**: add null length to crypto.subtle.deriveBits (Filip Skokan) [#​44876](https://togithub.com/nodejs/node/pull/44876)
- \[[`910fbd0ece`](https://togithub.com/nodejs/node/commit/910fbd0ece)] - **esm**: fix duplicated test (Geoffrey Booth) [#​44779](https://togithub.com/nodejs/node/pull/44779)
- \[[`bc00f3bde1`](https://togithub.com/nodejs/node/commit/bc00f3bde1)] - **fs**: fix opts.filter issue in cp async (Tho) [#​44922](https://togithub.com/nodejs/node/pull/44922)
- \[[`11d1c23fa0`](https://togithub.com/nodejs/node/commit/11d1c23fa0)] - **(SEMVER-MINOR)** **fs**: add `FileHandle.prototype.readLines` (Antoine du Hamel) [#​42590](https://togithub.com/nodejs/node/pull/42590)
- \[[`67fb76519a`](https://togithub.com/nodejs/node/commit/67fb76519a)] - **fs**: improve promise based readFile performance for big files (Ruben Bridgewater) [#​44295](https://togithub.com/nodejs/node/pull/44295)
- \[[`dc6379bdc2`](https://togithub.com/nodejs/node/commit/dc6379bdc2)] - **fs**: don't hard code name in validatePosition() (Colin Ihrig) [#​44767](https://togithub.com/nodejs/node/pull/44767)
- \[[`eb19b1e97c`](https://togithub.com/nodejs/node/commit/eb19b1e97c)] - **http**: be more aggressive to reply 400, 408 and 431 (ywave620) [#​44818](https://togithub.com/nodejs/node/pull/44818)
- \[[`4c869c8d9e`](https://togithub.com/nodejs/node/commit/4c869c8d9e)] - **(SEMVER-MINOR)** **http**: add writeEarlyHints function to ServerResponse (Wing) [#​44180](https://togithub.com/nodejs/node/pull/44180)
- \[[`9c7e66478c`](https://togithub.com/nodejs/node/commit/9c7e66478c)] - **(SEMVER-MINOR)** **http2**: make early hints generic (Yagiz Nizipli) [#​44820](https://togithub.com/nodejs/node/pull/44820)
- \[[`3f20e5b15c`](https://togithub.com/nodejs/node/commit/3f20e5b15c)] - **(SEMVER-MINOR)** **lib**: refactor transferable AbortSignal (flakey5) [#​44048](https://togithub.com/nodejs/node/pull/44048)
- \[[`ada7d82b16`](https://togithub.com/nodejs/node/commit/ada7d82b16)] - **lib**: require JSDoc in internal validators code (Rich Trott) [#​44896](https://togithub.com/nodejs/node/pull/44896)
- \[[`67eaa303af`](https://togithub.com/nodejs/node/commit/67eaa303af)] - **lib**: add cause to DOMException (flakey5) [#​44703](https://togithub.com/nodejs/node/pull/44703)
- \[[`0db86ee98e`](https://togithub.com/nodejs/node/commit/0db86ee98e)] - **meta**: update AUTHORS (Node.js GitHub Bot) [#​44930](https://togithub.com/nodejs/node/pull/44930)
- \[[`2efe4d985b`](https://togithub.com/nodejs/node/commit/2efe4d985b)] - **meta**: label test.js and test.md with test_runner label (Moshe Atlow) [#​44863](https://togithub.com/nodejs/node/pull/44863)
- \[[`fd9feb3a6c`](https://togithub.com/nodejs/node/commit/fd9feb3a6c)] - **meta**: update AUTHORS (Node.js GitHub Bot) [#​44857](https://togithub.com/nodejs/node/pull/44857)
- \[[`a854bb39c9`](https://togithub.com/nodejs/node/commit/a854bb39c9)] - **node-api**: create reference only when needed (Gerhard Stƶbich) [#​44827](https://togithub.com/nodejs/node/pull/44827)
- \[[`fd5c26b8db`](https://togithub.com/nodejs/node/commit/fd5c26b8db)] - **path**: change basename() argument from ext to suffix (Rich Trott) [#​44774](https://togithub.com/nodejs/node/pull/44774)
- \[[`803fbfb168`](https://togithub.com/nodejs/node/commit/803fbfb168)] - **process**: fix uid/gid validation to avoid crash (Tobias NieĆen) [#​44910](https://togithub.com/nodejs/node/pull/44910)
- \[[`9f2dd48fc3`](https://togithub.com/nodejs/node/commit/9f2dd48fc3)] - **src**: remove uid_t/gid_t casts (Tobias NieĆen) [#​44914](https://togithub.com/nodejs/node/pull/44914)
- \[[`3abb607f3a`](https://togithub.com/nodejs/node/commit/3abb607f3a)] - **src**: remove UncheckedMalloc(0) workaround (Tobias NieĆen) [#​44543](https://togithub.com/nodejs/node/pull/44543)
- \[[`0606f9298f`](https://togithub.com/nodejs/node/commit/0606f9298f)] - **src**: deduplicate setting RSA OAEP label (Tobias NieĆen) [#​44849](https://togithub.com/nodejs/node/pull/44849)
- \[[`daf3152f7e`](https://togithub.com/nodejs/node/commit/daf3152f7e)] - **src**: implement GetDetachedness() in MemoryRetainerNode (Joyee Cheung) [#​44803](https://togithub.com/nodejs/node/pull/44803)
- \[[`7ca77dd4ef`](https://togithub.com/nodejs/node/commit/7ca77dd4ef)] - **src**: avoid X509\_free in loops in crypto_x509.cc (Tobias NieĆen) [#​44855](https://togithub.com/nodejs/node/pull/44855)
- \[[`781ad96227`](https://togithub.com/nodejs/node/commit/781ad96227)] - **src**: use OnScopeLeave instead of multiple free() (Tobias NieĆen) [#​44852](https://togithub.com/nodejs/node/pull/44852)
- \[[`b27b336a7a`](https://togithub.com/nodejs/node/commit/b27b336a7a)] - **src**: remove ParseIP() in cares_wrap.cc (Tobias NieĆen) [#​44771](https://togithub.com/nodejs/node/pull/44771)
- \[[`f99f5d3c01`](https://togithub.com/nodejs/node/commit/f99f5d3c01)] - **(SEMVER-MINOR)** **src**: add detailed embedder process initialization API (Anna Henningsen) [#​44121](https://togithub.com/nodejs/node/pull/44121)
- \[[`281fd7a09a`](https://togithub.com/nodejs/node/commit/281fd7a09a)] - **src,stream**: improve DoWrite() and Write() (ywave620) [#​44434](https://togithub.com/nodejs/node/pull/44434)
- \[[`a33cc22bf7`](https://togithub.com/nodejs/node/commit/a33cc22bf7)] - **src,worker**: fix race of WorkerHeapSnapshotTaker (ywave620) [#​44745](https://togithub.com/nodejs/node/pull/44745)
- \[[`f300f197da`](https://togithub.com/nodejs/node/commit/f300f197da)] - **stream**: handle enqueuing chunks when a pending BYOB pull request exists (Daeyeon Jeong) [#​44770](https://togithub.com/nodejs/node/pull/44770)
- \[[`9ac029ea11`](https://togithub.com/nodejs/node/commit/9ac029ea11)] - **test**: bump memory limit for abort fatal error (Danielle Adams) [#​44984](https://togithub.com/nodejs/node/pull/44984)
- \[[`b9b671f25f`](https://togithub.com/nodejs/node/commit/b9b671f25f)] - **test**: debug watch mode inspect (Moshe Atlow) [#​44861](https://togithub.com/nodejs/node/pull/44861)
- \[[`2308b71d09`](https://togithub.com/nodejs/node/commit/2308b71d09)] - **test**: don't clobber RegExp.$\_ on startup (Ben Noordhuis) [#​44864](https://togithub.com/nodejs/node/pull/44864)
- \[[`fe91bebb67`](https://togithub.com/nodejs/node/commit/fe91bebb67)] - **test**: loosen test for negative timestamps in `test-fs-stat-date` (Livia Medeiros) [#​44707](https://togithub.com/nodejs/node/pull/44707)
- \[[`a080608552`](https://togithub.com/nodejs/node/commit/a080608552)] - **test**: check `--test` is disallowed in NODE_OPTIONS (Kohei Ueno) [#​44846](https://togithub.com/nodejs/node/pull/44846)
- \[[`dc2af265d7`](https://togithub.com/nodejs/node/commit/dc2af265d7)] - **test**: improve lib/internal/source_map/source_map.js coverage (MURAKAMI Masahiko) [#​42771](https://togithub.com/nodejs/node/pull/42771)
- \[[`60a05d6dea`](https://togithub.com/nodejs/node/commit/60a05d6dea)] - **test**: skip some binding tests on IBMi PASE (Richard Lau) [#​44810](https://togithub.com/nodejs/node/pull/44810)
- \[[`8dacedaa3d`](https://togithub.com/nodejs/node/commit/8dacedaa3d)] - **test**: remove unused variable in addon test (Joyee Cheung) [#​44809](https://togithub.com/nodejs/node/pull/44809)
- \[[`c54cee1c3f`](https://togithub.com/nodejs/node/commit/c54cee1c3f)] - **test**: check server status in test-tls-psk-client (Richard Lau) [#​44824](https://togithub.com/nodejs/node/pull/44824)
- \[[`ee3c6a4dc5`](https://togithub.com/nodejs/node/commit/ee3c6a4dc5)] - **test**: use async/await in test-debugger-exceptions (pete3249) [#​44690](https://togithub.com/nodejs/node/pull/44690)
- \[[`9f14625fe5`](https://togithub.com/nodejs/node/commit/9f14625fe5)] - **test**: use async/await in test-debugger-help (Chandana) [#​44686](https://togithub.com/nodejs/node/pull/44686)
- \[[`8033ad846b`](https://togithub.com/nodejs/node/commit/8033ad846b)] - **test**: update test-debugger-scripts to use await/async (mmeenapriya) [#​44692](https://togithub.com/nodejs/node/pull/44692)
- \[[`f4f08be384`](https://togithub.com/nodejs/node/commit/f4f08be384)] - **test**: use await in test-debugger-invalid-json (Anjana Krishnakumar Vellore) [#​44689](https://togithub.com/nodejs/node/pull/44689)
- \[[`d2f36169f3`](https://togithub.com/nodejs/node/commit/d2f36169f3)] - **test**: use async/await in test-debugger-random-port-with-inspect-port (Monu-Chaudhary) [#​44695](https://togithub.com/nodejs/node/pull/44695)
- \[[`ddf029725b`](https://togithub.com/nodejs/node/commit/ddf029725b)] - **test**: use async/await in test-debugger-heap-profiler (Brinda Ashar) [#​44693](https://togithub.com/nodejs/node/pull/44693)
- \[[`117f068250`](https://togithub.com/nodejs/node/commit/117f068250)] - **test**: use async/await in test-debugger-auto-resume (samyuktaprabhu) [#​44675](https://togithub.com/nodejs/node/pull/44675)
- \[[`143c428cae`](https://togithub.com/nodejs/node/commit/143c428cae)] - **test**: migrated from Promise chains to Async/Await (Rathi N Das) [#​44674](https://togithub.com/nodejs/node/pull/44674)
- \[[`e609a3309c`](https://togithub.com/nodejs/node/commit/e609a3309c)] - **test**: change promises to async/await in test-debugger-backtrace.js (Juliet Zhang) [#​44677](https://togithub.com/nodejs/node/pull/44677)
- \[[`eeabd23ca6`](https://togithub.com/nodejs/node/commit/eeabd23ca6)] - **test**: use async/await in test-debugger-sb-before-load (Hope OlaidĆ©) [#​44697](https://togithub.com/nodejs/node/pull/44697)
- \[[`5c63d1464e`](https://togithub.com/nodejs/node/commit/5c63d1464e)] - **test**: add extra tests for basename with ext option (Connor Burton) [#​44772](https://togithub.com/nodejs/node/pull/44772)
- \[[`f8b2d7a059`](https://togithub.com/nodejs/node/commit/f8b2d7a059)] - **test**: refactor to async/await (Divya Mohan) [#​44694](https://togithub.com/nodejs/node/pull/44694)
- \[[`9864bde9ab`](https://togithub.com/nodejs/node/commit/9864bde9ab)] - **test**: modify test-debugger-custom-port.js to use async-await (Priya Shastri) [#​44680](https://togithub.com/nodejs/node/pull/44680)
- \[[`af30823881`](https://togithub.com/nodejs/node/commit/af30823881)] - **test**: upgrade all 1024 bit RSA keys to 2048 bits (Momtchil Momtchev) [#​44498](https://togithub.com/nodejs/node/pull/44498)
- \[[`0fb669e31f`](https://togithub.com/nodejs/node/commit/0fb669e31f)] - **test**: update test-debugger-breakpoint-exists.js to use async/await (Archana Kamath) [#​44682](https://togithub.com/nodejs/node/pull/44682)
- \[[`cca253503e`](https://togithub.com/nodejs/node/commit/cca253503e)] - **test**: use async/await in test-debugger-preserve-breaks (poorvitusam) [#​44696](https://togithub.com/nodejs/node/pull/44696)
- \[[`0b2e8b1681`](https://togithub.com/nodejs/node/commit/0b2e8b1681)] - **test**: use async/await in test-debugger-profile (surbhirjain) [#​44684](https://togithub.com/nodejs/node/pull/44684)
- \[[`4db72a65cf`](https://togithub.com/nodejs/node/commit/4db72a65cf)] - **test**: change the promises to async/await in test-debugger-exec-scope.js (Ankita Khiratkar) [#​44685](https://togithub.com/nodejs/node/pull/44685)
- \[[`56c9c98963`](https://togithub.com/nodejs/node/commit/56c9c98963)] - **test**: fix test-runner-inspect (Moshe Atlow) [#​44620](https://togithub.com/nodejs/node/pull/44620)
- \[[`36227ed862`](https://togithub.com/nodejs/node/commit/36227ed862)] - **test**: fix watch mode test flake (Moshe Atlow) [#​44739](https://togithub.com/nodejs/node/pull/44739)
- \[[`3abd71a0ea`](https://togithub.com/nodejs/node/commit/3abd71a0ea)] - **test**: deflake watch mode tests (Moshe Atlow) [#​44621](https://togithub.com/nodejs/node/pull/44621)
- \[[`0c9f38f2be`](https://togithub.com/nodejs/node/commit/0c9f38f2be)] - **test**: split watch mode inspector tests to sequential (Moshe Atlow) [#​44551](https://togithub.com/nodejs/node/pull/44551)
- \[[`d762a34128`](https://togithub.com/nodejs/node/commit/d762a34128)] - **test_runner**: add --test-name-pattern CLI flag (Colin Ihrig)
- \[[`c7ece464a1`](https://togithub.com/nodejs/node/commit/c7ece464a1)] - **test_runner**: remove runtime experimental warning (Colin Ihrig) [#​44844](https://togithub.com/nodejs/node/pull/44844)
- \[[`3c1e9d41c8`](https://togithub.com/nodejs/node/commit/3c1e9d41c8)] - **test_runner**: support using `--inspect` with `--test` (Moshe Atlow) [#​44520](https://togithub.com/nodejs/node/pull/44520)
- \[[`4bdef48732`](https://togithub.com/nodejs/node/commit/4bdef48732)] - **tools**: remove faulty early termination logic from update-timezone.mjs (Darshan Sen) [#​44870](https://togithub.com/nodejs/node/pull/44870)
- \[[`19d8574996`](https://togithub.com/nodejs/node/commit/19d8574996)] - **tools**: fix timezone update tool (Darshan Sen) [#​44870](https://togithub.com/nodejs/node/pull/44870)
- \[[`ad8b8ae7d3`](https://togithub.com/nodejs/node/commit/ad8b8ae7d3)] - **tools**: update eslint to 8.25.0 (Node.js GitHub Bot) [#​44931](https://togithub.com/nodejs/node/pull/44931)
- \[[`fd99b17a4d`](https://togithub.com/nodejs/node/commit/fd99b17a4d)] - **tools**: make `utils.SearchFiles` deterministic (Bruno Pitrus) [#​44496](https://togithub.com/nodejs/node/pull/44496)
- \[[`131adece37`](https://togithub.com/nodejs/node/commit/131adece37)] - **tools**: fix typo in tools/update-authors.mjs (Darshan Sen) [#​44780](https://togithub.com/nodejs/node/pull/44780)
- \[[`ab22777e65`](https://togithub.com/nodejs/node/commit/ab22777e65)] - **tools**: refactor deprecated format in no-unescaped-regexp-dot (Madhuri) [#​44763](https://togithub.com/nodejs/node/pull/44763)
- \[[`3ad0fae89d`](https://togithub.com/nodejs/node/commit/3ad0fae89d)] - **tools**: update eslint-check.js to object style (andiemontoyeah) [#​44706](https://togithub.com/nodejs/node/pull/44706)
- \[[`e9d572a9bd`](https://togithub.com/nodejs/node/commit/e9d572a9bd)] - **tools**: update eslint to 8.24.0 (Node.js GitHub Bot) [#​44778](https://togithub.com/nodejs/node/pull/44778)
- \[[`984b0b4a6c`](https://togithub.com/nodejs/node/commit/984b0b4a6c)] - **tools**: update lint-md-dependencies to rollup@2.79.1 (Node.js GitHub Bot) [#​44776](https://togithub.com/nodejs/node/pull/44776)
- \[[`db5aeed702`](https://togithub.com/nodejs/node/commit/db5aeed702)] - **(SEMVER-MINOR)** **util**: add default value option to parsearg (Manuel Spigolon) [#​44631](https://togithub.com/nodejs/node/pull/44631)
- \[[`576ccdf125`](https://togithub.com/nodejs/node/commit/576ccdf125)] - **util**: increase robustness with primordials (Jordan Harband) [#​41212](https://togithub.com/nodejs/node/pull/41212)
### [`v18.10.0`](https://togithub.com/nodejs/node/releases/tag/v18.10.0): 2022-09-28, Version 18.10.0 (Current), @​RafaelGSS
[Compare Source](https://togithub.com/nodejs/node/compare/v18.9.1...v18.10.0)
- **doc**:
- (SEMVER-MINOR) deprecate modp1, modp2, and modp5 groups (Tobias NieĆen) [#​44588](https://togithub.com/nodejs/node/pull/44588)
- add legendecas to TSC list (Michael Dawson) [#​44662](https://togithub.com/nodejs/node/pull/44662)
- move `policy` docs to the `permissions` scope (Rafael Gonzaga) [#​44222](https://togithub.com/nodejs/node/pull/44222)
- **gyp**:
- libnode for ios app embedding (chexiongsheng) [#​44210](https://togithub.com/nodejs/node/pull/44210)
- **http**:
- (SEMVER-MINOR) throw error on content-length mismatch (sidwebworks) [#​44588](https://togithub.com/nodejs/node/pull/44378)
- **stream**:
- (SEMVER-MINOR) add `ReadableByteStream.tee()` (Daeyeon Jeong) [#​44505](https://togithub.com/nodejs/node/pull/44505)
##### Commits
- \[[`f497368679`](https://togithub.com/nodejs/node/commit/f497368679)] - **benchmark**: fix startup benchmark (Evan Lucas) [#​44727](https://togithub.com/nodejs/node/pull/44727)
- \[[`0c9a94684e`](https://togithub.com/nodejs/node/commit/0c9a94684e)] - **benchmark**: add stream destroy benchmark (SindreXie) [#​44533](https://togithub.com/nodejs/node/pull/44533)
- \[[`9c5c1459a8`](https://togithub.com/nodejs/node/commit/9c5c1459a8)] - **bootstrap**: clean up inspector console methods during serialization (Joyee Cheung) [#​44279](https://togithub.com/nodejs/node/pull/44279)
- \[[`19f67dba8a`](https://togithub.com/nodejs/node/commit/19f67dba8a)] - **bootstrap**: remove unused global parameter in per-context scripts (Joyee Cheung) [#​44472](https://togithub.com/nodejs/node/pull/44472)
- \[[`9da11426f6`](https://togithub.com/nodejs/node/commit/9da11426f6)] - **build**: remove redundant entry in crypto (Jiawen Geng) [#​44604](https://togithub.com/nodejs/node/pull/44604)
- \[[`70898b4e67`](https://togithub.com/nodejs/node/commit/70898b4e67)] - **build**: rewritten the Android build system (BuShe Pie) [#​44207](https://togithub.com/nodejs/node/pull/44207)
- \[[`a733f7faac`](https://togithub.com/nodejs/node/commit/a733f7faac)] - ***Revert*** "**build**: go faster, drop -fno-omit-frame-pointer" (Ben Noordhuis) [#​44566](https://togithub.com/nodejs/node/pull/44566)
- \[[`1315a83333`](https://togithub.com/nodejs/node/commit/1315a83333)] - **build**: fix bad upstream merge (Stephen Gallagher) [#​44642](https://togithub.com/nodejs/node/pull/44642)
- \[[`993bd9b134`](https://togithub.com/nodejs/node/commit/993bd9b134)] - **crypto**: restrict PBKDF2 args to signed int (Tobias NieĆen) [#​44575](https://togithub.com/nodejs/node/pull/44575)
- \[[`ca5fb67b4e`](https://togithub.com/nodejs/node/commit/ca5fb67b4e)] - **deps**: update to ngtcp2 0.8.1 and nghttp3 0.7.0 (Tobias NieĆen) [#​44622](https://togithub.com/nodejs/node/pull/44622)
- \[[`8da1d6ebc4`](https://togithub.com/nodejs/node/commit/8da1d6ebc4)] - **deps**: update corepack to 0.14.1 (Node.js GitHub Bot) [#​44704](https://togithub.com/nodejs/node/pull/44704)
- \[[`d36c4a3088`](https://togithub.com/nodejs/node/commit/d36c4a3088)] - **deps**: update ngtcp2 update instructions (Tobias NieĆen) [#​44619](https://togithub.com/nodejs/node/pull/44619)
- \[[`7129106aa0`](https://togithub.com/nodejs/node/commit/7129106aa0)] - **deps**: upgrade npm to 8.19.2 (npm team) [#​44632](https://togithub.com/nodejs/node/pull/44632)
- \[[`3cc8f4bb56`](https://togithub.com/nodejs/node/commit/3cc8f4bb56)] - **deps**: update to uvwasi 0.0.13 (Colin Ihrig) [#​44524](https://togithub.com/nodejs/node/pull/44524)
- \[[`4686579d4b`](https://togithub.com/nodejs/node/commit/4686579d4b)] - **dns**: remove unnecessary parameter from validateOneOf (Yagiz Nizipli) [#​44635](https://togithub.com/nodejs/node/pull/44635)
- \[[`729dd95f1f`](https://togithub.com/nodejs/node/commit/729dd95f1f)] - **dns**: refactor default resolver (Joyee Cheung) [#​44541](https://togithub.com/nodejs/node/pull/44541)
- \[[`6dc038262a`](https://togithub.com/nodejs/node/commit/6dc038262a)] - **doc**: mention git node backport (RafaelGSS) [#​44764](https://togithub.com/nodejs/node/pull/44764)
- \[[`fd971f5176`](https://togithub.com/nodejs/node/commit/fd971f5176)] - **doc**: ensure to revert node_version changes (Rafael Gonzaga) [#​44760](https://togithub.com/nodejs/node/pull/44760)
- \[[`f274b08f8e`](https://togithub.com/nodejs/node/commit/f274b08f8e)] - **doc**: fix description for `napi_get_cb_info()` in `n-api.md` (Daeyeon Jeong) [#​44761](https://togithub.com/nodejs/node/pull/44761)
- \[[`2502f2353d`](https://togithub.com/nodejs/node/commit/2502f2353d)] - **doc**: update the deprecation for exit code to clarify its scope (Daeyeon Jeong) [#​44714](https://togithub.com/nodejs/node/pull/44714)
- \[[`064543d0ae`](https://togithub.com/nodejs/node/commit/064543d0ae)] - **doc**: update guidance for adding new modules (Michael Dawson) [#​44576](https://togithub.com/nodejs/node/pull/44576)
- \[[`33a2f17534`](https://togithub.com/nodejs/node/commit/33a2f17534)] - **doc**: add registry number for Electron 22 (Keeley Hammond) [#​44748](https://togithub.com/nodejs/node/pull/44748)
- \[[`10a0d75c26`](https://togithub.com/nodejs/node/commit/10a0d75c26)] - **doc**: include code examples for webstreams consumers (Lucas Santos) [#​44387](https://togithub.com/nodejs/node/pull/44387)
- \[[`4dbe4a010c`](https://togithub.com/nodejs/node/commit/4dbe4a010c)] - **doc**: mention where to push security commits (RafaelGSS) [#​44691](https://togithub.com/nodejs/node/pull/44691)
- \[[`82cb8151ad`](https://togithub.com/nodejs/node/commit/82cb8151ad)] - **doc**: remove extra space on threadpool usage (Connor Burton) [#​44734](https://togithub.com/nodejs/node/pull/44734)
- \[[`6ef9af2748`](https://togithub.com/nodejs/node/commit/6ef9af2748)] - **doc**: make legacy banner slightly less bright (Rich Trott) [#​44665](https://togithub.com/nodejs/node/pull/44665)
- \[[`b209c83e66`](https://togithub.com/nodejs/node/commit/b209c83e66)] - **doc**: improve building doc for Windows Powershell (Brian Muenzenmeyer) [#​44625](https://togithub.com/nodejs/node/pull/44625)
- \[[`05b17e9250`](https://togithub.com/nodejs/node/commit/05b17e9250)] - **doc**: maintain only one list of MODP groups (Tobias NieĆen) [#​44644](https://togithub.com/nodejs/node/pull/44644)
- \[[`ec1cbdb69b`](https://togithub.com/nodejs/node/commit/ec1cbdb69b)] - **doc**: add legendecas to TSC list (Michael Dawson) [#​44662](https://togithub.com/nodejs/node/pull/44662)
- \[[`9341fb4446`](https://togithub.com/nodejs/node/commit/9341fb4446)] - **doc**: remove comma in README.md (Taha-Chaudhry) [#​44599](https://togithub.com/nodejs/node/pull/44599)
- \[[`3dabb44dda`](https://togithub.com/nodejs/node/commit/3dabb44dda)] - **doc**: use serial comma in report docs (Daeyeon Jeong) [#​44608](https://togithub.com/nodejs/node/pull/44608)
- \[[`226d90a95a`](https://togithub.com/nodejs/node/commit/226d90a95a)] - **doc**: use serial comma in stream docs (Daeyeon Jeong) [#​44609](https://togithub.com/nodejs/node/pull/44609)
- \[[`3f710fa636`](https://togithub.com/nodejs/node/commit/3f710fa636)] - **doc**: remove empty line in YAML block (Claudio Wunder) [#​44617](https://togithub.com/nodejs/node/pull/44617)
- \[[`4ad1b0abc3`](https://togithub.com/nodejs/node/commit/4ad1b0abc3)] - **(SEMVER-MINOR)** **doc**: deprecate modp1, modp2, and modp5 groups (Tobias NieĆen) [#​44588](https://togithub.com/nodejs/node/pull/44588)
- \[[`2d92610525`](https://togithub.com/nodejs/node/commit/2d92610525)] - **doc**: remove old OpenSSL ENGINE constants (Tobias NieĆen) [#​44589](https://togithub.com/nodejs/node/pull/44589)
- \[[`03705639c4`](https://togithub.com/nodejs/node/commit/03705639c4)] - **doc**: fix heading levels for test runner hooks (Fabian Meyer) [#​44603](https://togithub.com/nodejs/node/pull/44603)
- \[[`6c557346a7`](https://togithub.com/nodejs/node/commit/6c557346a7)] - **doc**: fix errors in http.md (Luigi Pinca) [#​44587](https://togithub.com/nodejs/node/pull/44587)
- \[[`48d944b71c`](https://togithub.com/nodejs/node/commit/48d944b71c)] - **doc**: fix vm.Script createCachedData example (Chengzhong Wu) [#​44487](https://togithub.com/nodejs/node/pull/44487)
- \[[`2813323120`](https://togithub.com/nodejs/node/commit/2813323120)] - **doc**: mention how to get commit release (Rafael Gonzaga) [#​44572](https://togithub.com/nodejs/node/pull/44572)
- \[[`ea7b44d474`](https://togithub.com/nodejs/node/commit/ea7b44d474)] - **doc**: fix link in `process.md` (Antoine du Hamel) [#​44594](https://togithub.com/nodejs/node/pull/44594)
- \[[`39b65d2fb7`](https://togithub.com/nodejs/node/commit/39b65d2fb7)] - **doc**: do not use weak MODP group in example (Tobias NieĆen) [#​44585](https://togithub.com/nodejs/node/pull/44585)
- \[[`f5549afd90`](https://togithub.com/nodejs/node/commit/f5549afd90)] - **doc**: remove ebpf from supported tooling list (Rafael Gonzaga) [#​44549](https://togithub.com/nodejs/node/pull/44549)
- \[[`a3360b1f4f`](https://togithub.com/nodejs/node/commit/a3360b1f4f)] - **doc**: emphasize that createCipher is never secure (Tobias NieĆen) [#​44538](https://togithub.com/nodejs/node/pull/44538)
- \[[`4e6f7862ba`](https://togithub.com/nodejs/node/commit/4e6f7862ba)] - **doc**: document attribute Script.cachedDataRejected (Chengzhong Wu) [#​44451](https://togithub.com/nodejs/node/pull/44451)
- \[[`01e584ecab`](https://togithub.com/nodejs/node/commit/01e584ecab)] - **doc**: move policy docs to the permissions scope (Rafael Gonzaga) [#​44222](https://togithub.com/nodejs/node/pull/44222)
- \[[`57dac53c22`](https://togithub.com/nodejs/node/commit/57dac53c22)] - **doc,crypto**: cleanup removed pbkdf2 behaviours (Filip Skokan) [#​44733](https://togithub.com/nodejs/node/pull/44733)
- \[[`c209bd6fb9`](https://togithub.com/nodejs/node/commit/c209bd6fb9)] - **doc,inspector**: document changes of inspector.close (Chengzhong Wu) [#​44628](https://togithub.com/nodejs/node/pull/44628)
- \[[`9b3b7d6978`](https://togithub.com/nodejs/node/commit/9b3b7d6978)] - **esm,loader**: tidy ESMLoader internals (Jacob Smith) [#​44701](https://togithub.com/nodejs/node/pull/44701)
- \[[`daf63d2fa3`](https://togithub.com/nodejs/node/commit/daf63d2fa3)] - **fs**: fix typo in mkdir example (SergeyTsukanov) [#​44791](https://togithub.com/nodejs/node/pull/44791)
- \[[`85ab2f857f`](https://togithub.com/nodejs/node/commit/85ab2f857f)] - **fs**: remove unused option in `fs.fstatSync()` (Livia Medeiros) [#​44613](https://togithub.com/nodejs/node/pull/44613)
- \[[`a6091f5496`](https://togithub.com/nodejs/node/commit/a6091f5496)] - **gyp**: libnode for ios app embedding (chexiongsheng) [#​44210](https://togithub.com/nodejs/node/pull/44210)
- \[[`f158656e4c`](https://togithub.com/nodejs/node/commit/f158656e4c)] - **(SEMVER-MINOR)** **http**: throw error on content-length mismatch (sidwebworks) [#​44378](https://togithub.com/nodejs/node/pull/44378)
- \[[`1b160517f5`](https://togithub.com/nodejs/node/commit/1b160517f5)] - **inspector**: expose inspector.close on workers (Chengzhong Wu) [#​44489](https://togithub.com/nodejs/node/pull/44489)
- \[[`a2eb55a2c9`](https://togithub.com/nodejs/node/commit/a2eb55a2c9)] - **lib**: don't match `sourceMappingURL` in strings (Alan Agius) [#​44658](https://togithub.com/nodejs/node/pull/44658)
- \[[`2baf532518`](https://togithub.com/nodejs/node/commit/2baf532518)] - **lib**: fix reference leak (falsandtru) [#​44499](https://togithub.com/nodejs/node/pull/44499)
- \[[`d8d34ae6bc`](https://togithub.com/nodejs/node/commit/d8d34ae6bc)] - **lib**: reset `RegExp` statics before running user code (Antoine du Hamel) [#​44247](https://togithub.com/nodejs/node/pull/44247)
- \[[`eb3635184b`](https://togithub.com/nodejs/node/commit/eb3635184b)] - **lib,test**: fix bug in InternalSocketAddress (Tobias NieĆen) [#​44618](https://togithub.com/nodejs/node/pull/44618)
- \[[`74dc4d198f`](https://togithub.com/nodejs/node/commit/74dc4d198f)] - **meta**: update AUTHORS (Node.js GitHub Bot) [#​44777](https://togithub.com/nodejs/node/pull/44777)
- \[[`97d2ed7296`](https://togithub.com/nodejs/node/commit/97d2ed7296)] - **meta**: add mailmap entry for dnlup (Rich Trott) [#​44716](https://togithub.com/nodejs/node/pull/44716)
- \[[`35fbd2cc14`](https://togithub.com/nodejs/node/commit/35fbd2cc14)] - **meta**: update AUTHORS (Node.js GitHub Bot) [#​44705](https://togithub.com/nodejs/node/pull/44705)
- \[[`c5c1bc40a2`](https://togithub.com/nodejs/node/commit/c5c1bc40a2)] - **meta**: move dnlup to emeriti (dnlup) [#​44667](https://togithub.com/nodejs/node/pull/44667)
- \[[`c62dfe0427`](https://togithub.com/nodejs/node/commit/c62dfe0427)] - **meta**: update test_runner in label-pr-config (Shrujal Shah) [#​44615](https://togithub.com/nodejs/node/pull/44615)
- \[[`fe56efd0bc`](https://togithub.com/nodejs/node/commit/fe56efd0bc)] - **meta**: update AUTHORS (Node.js GitHub Bot) [#​44591](https://togithub.com/nodejs/node/pull/44591)
- \[[`4436ffb536`](https://togithub.com/nodejs/node/commit/4436ffb536)] - **module**: open stat/readPackage to mutations (MaĆ«l Nison) [#​44537](https://togithub.com/nodejs/node/pull/44537)
- \[[`f8ec946c82`](https://togithub.com/nodejs/node/commit/f8ec946c82)] - **module**: exports & imports map invalid slash deprecation (Guy Bedford) [#​44477](https://togithub.com/nodejs/node/pull/44477)
- \[[`64cb43a2b6`](https://togithub.com/nodejs/node/commit/64cb43a2b6)] - **node-api**: add deprecation code of uncaught exception (Chengzhong Wu) [#​44624](https://togithub.com/nodejs/node/pull/44624)
- \[[`ce1704c2c7`](https://togithub.com/nodejs/node/commit/ce1704c2c7)] - **src**: avoid using v8 on Isolate termination (Santiago Gimeno) [#​44669](https://togithub.com/nodejs/node/pull/44669)
- \[[`3036b85d71`](https://togithub.com/nodejs/node/commit/3036b85d71)] - **src**: remove \<unistd.h> from node_os.cc (Tobias NieĆen) [#​44668](https://togithub.com/nodejs/node/pull/44668)
- \[[`29f57b7899`](https://togithub.com/nodejs/node/commit/29f57b7899)] - **src**: avoid copy when creating Blob (Tobias NieĆen) [#​44616](https://togithub.com/nodejs/node/pull/44616)
- \[[`75cfb13ea6`](https://togithub.com/nodejs/node/commit/75cfb13ea6)] - **src**: make ReqWrap weak (Rafael Gonzaga) [#​44074](https://togithub.com/nodejs/node/pull/44074)
- \[[`c12abb5ece`](https://togithub.com/nodejs/node/commit/c12abb5ece)] - **src**: make NearHeapLimitCallback() more robust (Joyee Cheung) [#​44581](https://togithub.com/nodejs/node/pull/44581)
- \[[`81ea507e8e`](https://togithub.com/nodejs/node/commit/81ea507e8e)] - **src**: dump isolate stats when process exits (daomingq) [#​44534](https://togithub.com/nodejs/node/pull/44534)
- \[[`687844822f`](https://togithub.com/nodejs/node/commit/687844822f)] - **src**: consolidate environment cleanup queue (Chengzhong Wu) [#​44379](https://togithub.com/nodejs/node/pull/44379)
- \[[`3d42aaaac0`](https://togithub.com/nodejs/node/commit/3d42aaaac0)] - **stream**: handle a pending pull request from a released reader (Daeyeon Jeong) [#​44702](https://togithub.com/nodejs/node/pull/44702)
- \[[`73ad9db6c5`](https://togithub.com/nodejs/node/commit/73ad9db6c5)] - **stream**: refactor use es2020 statement (SindreXie) [#​44533](https://togithub.com/nodejs/node/pull/44533)
- \[[`0af6e420b3`](https://togithub.com/nodejs/node/commit/0af6e420b3)] - **stream**: remove `abortReason` from `WritableStreamDefaultController` (Daeyeon Jeong) [#​44540](https://togithub.com/nodejs/node/pull/44540)
- \[[`2f2f8d5821`](https://togithub.com/nodejs/node/commit/2f2f8d5821)] - **(SEMVER-MINOR)** **stream**: add `ReadableByteStream.tee()` (Daeyeon Jeong) [#​44505](https://togithub.com/nodejs/node/pull/44505)
- \[[`667e8bf3fb`](https://togithub.com/nodejs/node/commit/667e8bf3fb)] - **stream**: fix `writableStream.abort()` (Daeyeon Jeong) [#​44327](https://togithub.com/nodejs/node/pull/44327)
- \[[`3112d5dae0`](https://togithub.com/nodejs/node/commit/3112d5dae0)] - **test**: verify napi_remove_wrap with napi_delete_reference (Chengzhong Wu) [#​44754](https://togithub.com/nodejs/node/pull/44754)
- \[[`b512436841`](https://togithub.com/nodejs/node/commit/b512436841)] - **test**: change promises to async/await (Madhulika Sharma) [#​44683](https://togithub.com/nodejs/node/pull/44683)
- \[[`858631f720`](https://togithub.com/nodejs/node/commit/858631f720)] - **test**: use async/await in test-debugger-invalid-args (Nupur Chauhan) [#​44678](https://togithub.com/nodejs/node/pull/44678)
- \[[`6c9ded810c`](https://togithub.com/nodejs/node/commit/6c9ded810c)] - **test**: update test-debugger-low-level to use await/async (Meghana Ramesh) [#​44688](https://togithub.com/nodejs/node/pull/44688)
- \[[`945aa74e57`](https://togithub.com/nodejs/node/commit/945aa74e57)] - **test**: check that sysconf returns a positive value (Tobias NieĆen) [#​44666](https://togithub.com/nodejs/node/pull/44666)
- \[[`79f0f48a6f`](https://togithub.com/nodejs/node/commit/79f0f48a6f)] - **test**: change promise to async/await in debugger-watcher (āPooja) [#​44687](https://togithub.com/nodejs/node/pull/44687)
- \[[`a56cb65bd6`](https://togithub.com/nodejs/node/commit/a56cb65bd6)] - **test**: fix addon tests compilation with OpenSSL 1.1.1 (Adam Majer) [#​44725](https://togithub.com/nodejs/node/pull/44725)
- \[[`8a68a80a06`](https://togithub.com/nodejs/node/commit/8a68a80a06)] - **test**: fix test-performance-measure (smitley) [#​44637](https://togithub.com/nodejs/node/pull/44637)
- \[[`55de0136b3`](https://togithub.com/nodejs/node/commit/55de0136b3)] - **test**: improve lib/readline.js coverage (MURAKAMI Masahiko) [#​42686](https://togithub.com/nodejs/node/pull/42686)
- \[[`a3095d217f`](https://togithub.com/nodejs/node/commit/a3095d217f)] - **test**: fix `test-repl` not validating leaked globals properly (Antoine du Hamel) [#​44640](https://togithub.com/nodejs/node/pull/44640)
- \[[`7db2974692`](https://togithub.com/nodejs/node/commit/7db2974692)] - **test**: ignore stale process cleanup failures on Windows (Joyee Cheung) [#​44480](https://togithub.com/nodejs/node/pull/44480)
- \[[`6c35f338c3`](https://togithub.com/nodejs/node/commit/6c35f338c3)] - **test**: use python3 instead of python (Luigi Pinca) [#​44545](https://togithub.com/nodejs/node/pull/44545)
- \[[`20e04c6d44`](https://togithub.com/nodejs/node/commit/20e04c6d44)] - **test**: fix DebugSymbolsTest.ReqWrapList on PPC64LE (Daniel Bevenius) [#​44341](https://togithub.com/nodejs/node/pull/44341)
- \[[`eb25fe73b0`](https://togithub.com/nodejs/node/commit/eb25fe73b0)] - **test**: add more cases for parse-encoding (Tony Gorez) [#​44427](https://togithub.com/nodejs/node/pull/44427)
- \[[`5ab3bc9419`](https://togithub.com/nodejs/node/commit/5ab3bc9419)] - **test_runner**: include stack of uncaught exceptions (Moshe Atlow) [#​44614](https://togithub.com/nodejs/node/pull/44614)
- \[[`752e1472e1`](https://togithub.com/nodejs/node/commit/752e1472e1)] - **tls**: fix out-of-bounds read in ClientHelloParser (Tobias NieĆen) [#​44580](https://togithub.com/nodejs/node/pull/44580)
- \[[`0cddb0af99`](https://togithub.com/nodejs/node/commit/0cddb0af99)] - **tools**: add update-llhttp.sh (Paolo Insogna) [#​44652](https://togithub.com/nodejs/node/pull/44652)
- \[[`ef0dc47df9`](https://togithub.com/nodejs/node/commit/ef0dc47df9)] - **tools**: fix typo in update-nghttp2.sh (Luigi Pinca) [#​44664](https://togithub.com/nodejs/node/pull/44664)
- \[[`0df181a5a1`](https://togithub.com/nodejs/node/commit/0df181a5a1)] - **tools**: add timezone update workflow (Lenvin Gonsalves) [#​43988](https://togithub.com/nodejs/node/pull/43988)
- \[[`dd4348900d`](https://togithub.com/nodejs/node/commit/dd4348900d)] - **tools**: update eslint to 8.23.1 (Node.js GitHub Bot) [#​44639](https://togithub.com/nodejs/node/pull/44639)
- \[[`b9cfb71e12`](https://togithub.com/nodejs/node/commit/b9cfb71e12)] - **tools**: update lint-md-dependencies to [@​rollup/plugin-node-resolve](https://togithub.com/rollup/plugin-node-resolve)[@​14](https://togithub.com/14).1.0 (Node.js GitHub Bot) [#​44638](https://togithub.com/nodejs/node/pull/44638)
- \[[`5ae142d7ad`](https://togithub.com/nodejs/node/commit/5ae142d7ad)] - **tools**: update gyp-next to v0.13.0 (Jiawen Geng) [#​44605](https://togithub.com/nodejs/node/pull/44605)
- \[[`5dd86c3faf`](https://togithub.com/nodejs/node/commit/5dd86c3faf)] - **tools**: update lint-md-dependencies to [@​rollup/plugin-node-resolve](https://togithub.com/rollup/plugin-node-resolve)[@​14](https://togithub.com/14).0.1 (Node.js GitHub Bot) [#​44590](https://togithub.com/nodejs/node/pull/44590)
- \[[`caad4748cf`](https://togithub.com/nodejs/node/commit/caad4748cf)] - **tools**: increase timeout of running WPT (Joyee Cheung) [#​44574](https://togithub.com/nodejs/node/pull/44574)
- \[[`5db9779f14`](https://togithub.com/nodejs/node/commit/5db9779f14)] - **tools**: fix shebang to use python3 by default (Himself65) [#​44531](https://togithub.com/nodejs/node/pull/44531)
- \[[`9aa6a560e9`](https://togithub.com/nodejs/node/commit/9aa6a560e9)] - **v8**: add setHeapSnapshotNearHeapLimit (theanarkh) [#​44420](https://togithub.com/nodejs/node/pull/44420)
- \[[`360b74e94f`](https://togithub.com/nodejs/node/commit/360b74e94f)] - **win**: fix fs.realpath.native for long paths (StefanStojanovic) [#​44536](https://togithub.com/nodejs/node/pull/44536)
### [`v18.9.1`](https://togithub.com/nodejs/node/releases/tag/v18.9.1): 2022-09-23, Version 18.9.1 (Current), @​RafaelGSS
[Compare Source](https://togithub.com/nodejs/node/compare/v18.9.0...v18.9.1)
- **[CVE-2022-32212](https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-32212)**: DNS rebinding in --inspect on macOS (High)
- Insufficient fix for macOS devices on v18.5.0
- **[CVE-2022-32222](https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-32222)**: Node 18 reads openssl.cnf from /home/iojs/build/ upon startup on MacOS (Medium)
- **[CVE-2022-32213](https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-32213)**: HTTP Request Smuggling - Flawed Parsing of Transfer-Encoding (Medium)
- Insufficient fix on v18.5.0
- **[CVE-2022-32215](https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-32215)**: HTTP Request Smuggling - Incorrect Parsing of Multi-line Transfer-Encoding (Medium)
- **[CVE-2022-35256](https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-35256)**: HTTP Request Smuggling - Incorrect Parsing of Header Fields (Medium)
- **[CVE-2022-35255](https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-35255)**: Weak randomness in WebCrypto keygen
More detailed information on each of the vulnerabilities can be found in [September 22nd 2022 Security Releases](https://nodejs.org/en/blog/vulnerability/september-2022-security-releases/) blog post.
##### llhttp updated to 6.0.10
`llhttp` is updated to 6.0.10 which includes fixes for the following vulnerabilities.
- **HTTP Request Smuggling - CVE-2022-32213 bypass via obs-fold mechanic (Medium)([CVE-2022-32213](https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-32213) )**: The `llhttp` parser in the `http` module does not correctly parse and validate Transfer-Encoding headers. This can lead to HTTP Request Smuggling (HRS).
- **HTTP Request Smuggling - Incorrect Parsing of Multi-line Transfer-Encoding (Medium)([CVE-2022-32215](https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-32215))**: The `llhttp` parser in the `http` module does not correctly handle multi-line Transfer-Encoding headers. This can lead to HTTP Request Smuggling (HRS).
- **HTTP Request Smuggling - Incorrect Parsing of Header Fields (Medium)([CVE-35256](https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-35256))**: The llhttp parser in the `http` does not correctly handle header fields that are not terminated with CLRF. This can lead to HTTP Request Smuggling (HRS).
##### Commits
- \[[`0c2a5723be`](https://togithub.com/nodejs/node/commit/0c2a5723be)] - **crypto**: fix weak randomness in WebCrypto keygen (Ben Noordhuis) [nodejs-private/node-private#](https://togithub.com/nodejs-private/node-private/pull/346)
- \[[`ffb6f4d51d`](https://togithub.com/nodejs/node/commit/ffb6f4d51d)] - **deps**: MacOS - fix location of OpenSSL config file (Michael Dawson) [nodejs-private/node-private#​345](https://togithub.com/nodejs-private/node-private/pull/345)
- \[[`01bffcdd93`](https://togithub.com/nodejs/node/commit/01bffcdd93)] - **http**: disable chunked encoding when OBS fold is used (Paolo Insogna) [nodejs-private/node-private#​341](https://togithub.com/nodejs-private/node-private/pull/341)
- \[[`2c379d341d`](https://togithub.com/nodejs/node/commit/2c379d341d)] - **src**: fix IPv4 non routable validation (RafaelGSS) [nodejs-private/node-private#​337](https://togithub.com/nodejs-private/node-private/pull/337)
### [`v18.9.0`](https://togithub.com/nodejs/node/releases/tag/v18.9.0): 2022-09-08, Version 18.9.0 (Current), @​RafaelGSS
[Compare Source](https://togithub.com/nodejs/node/compare/v18.8.0...v18.9.0)
- **doc**
- add daeyeon to collaborators (Daeyeon Jeong) [#​44355](https://togithub.com/nodejs/node/pull/44355)
- **lib**
- (SEMVER-MINOR) add diagnostics channel for process and worker (theanarkh) [#​44045](https://togithub.com/nodejs/node/pull/44045)
- **os**
- (SEMVER-MINOR) add machine method (theanarkh) [#​44416](https://togithub.com/nodejs/node/pull/44416)
- **report**
- (SEMVER-MINOR) expose report public native apis (Chengzhong Wu) [#​44255](https://togithub.com/nodejs/node/pull/44255)
- **src**
- (SEMVER-MINOR) expose environment RequestInterrupt api (Chengzhong Wu) [#​44362](https://togithub.com/nodejs/node/pull/44362)
- **vm**
- include vm context in the embedded snapshot (Joyee Cheung) [#​44252](https://togithub.com/nodejs/node/pull/44252)
##### Commits
- \[[`e27e709d3c`](https://togithub.com/nodejs/node/commit/e27e709d3c)] - **build**: add --libdir flag to configure (Stephen Gallagher) [#​44361](https://togithub.com/nodejs/node/pull/44361)
- \[[`30da2b4d89`](https://togithub.com/nodejs/node/commit/30da2b4d89)] - **build**: added NINJA env to customize ninja binary (Jeff Dickey) [#​44293](https://togithub.com/nodejs/node/pull/44293)
- \[[`3c5354869e`](https://togithub.com/nodejs/node/commit/3c5354869e)] - **cluster**: fix cluster rr distribute error (theanarkh) [#​44202](https://togithub.com/nodejs/node/pull/44202)
- \[[`5cefd02618`](https://togithub.com/nodejs/node/commit/5cefd02618)] - **crypto**: handle invalid prepareAsymmetricKey JWK inputs (Filip Skokan) [#​44475](https://togithub.com/nodejs/node/pull/44475)
- \[[`c868e36385`](https://togithub.com/nodejs/node/commit/c868e36385)] - **crypto**: add digest name to INVALID_DIGEST errors (Tobias NieĆen) [#​44468](https://togithub.com/nodejs/node/pull/44468)
- \[[`35cbe1ad85`](https://togithub.com/nodejs/node/commit/35cbe1ad85)] - **crypto**: use actual option name in error message (Tobias NieĆen) [#​44455](https://togithub.com/nodejs/node/pull/44455)
- \[[`c3dbe18e4c`](https://togithub.com/nodejs/node/commit/c3dbe18e4c)] - **crypto**: simplify control flow in HKDF (Tobias NieĆen) [#​44272](https://togithub.com/nodejs/node/pull/44272)
- \[[`28781a1f7e`](https://togithub.com/nodejs/node/commit/28781a1f7e)] - **crypto**: improve RSA-PSS digest error messages (Tobias NieĆen) [#​44307](https://togithub.com/nodejs/node/pull/44307)
- \[[`b1eafe14fd`](https://togithub.com/nodejs/node/commit/b1eafe14fd)] - **debugger**: decrease timeout used to wait for the port to be free (Joyee Cheung) [#​44359](https://togithub.com/nodejs/node/pull/44359)
- \[[`8ef5c40a83`](https://togithub.com/nodejs/node/commit/8ef5c40a83)] - **deps**: update corepack to 0.14.0 (Node.js GitHub Bot) [#​44509](https://togithub.com/nodejs/node/pull/44509)
- \[[`cf19a79dfc`](https://togithub.com/nodejs/node/commit/cf19a79dfc)] - **deps**: upgrade npm to 8.19.1 (npm team) [#​44486](https://togithub.com/nodejs/node/pull/44486)
- \[[`c5630ad1a7`](https://togithub.com/nodejs/node/commit/c5630ad1a7)] - **deps**: V8: backport [`ff8d67c`](https://togithub.com/nodejs/node/commit/ff8d67c88449) (MichaĆ«l Zasso) [#​44423](https://togithub.com/nodejs/node/pull/44423)
- \[[`255e7fbd08`](https://togithub.com/nodejs/node/commit/255e7fbd08)] - **deps**: update Acorn to v8.8.0 (MichaĆ«l Zasso) [#​44437](https://togithub.com/nodejs/node/pull/44437)
- \[[`754d26a53e`](https://togithub.com/nodejs/node/commit/754d26a53e)] - **deps**: patch V8 to 10.2.154.15 (MichaĆ«l Zasso) [#​44294](https://togithub.com/nodejs/node/pull/44294)
- \[[`1b50ff2600`](https://togithub.com/nodejs/node/commit/1b50ff2600)] - **deps**: update icu tzdata to 2022b (MatĆas Zúñiga) [#​44283](https://togithub.com/nodejs/node/pull/44283)
- \[[`1e451dca99`](https://togithub.com/nodejs/node/commit/1e451dca99)] - **deps**: upgrade llhttp to 6.0.9 (Paolo Insogna) [#​44344](https://togithub.com/nodejs/node/pull/44344)
- \[[`57da3db522`](https://togithub.com/nodejs/node/commit/57da3db522)] - **deps**: update undici to 5.9.1 (Node.js GitHub Bot) [#​44319](https://togithub.com/nodejs/node/pull/44319)
- \[[`1c87a7e8f6`](https://togithub.com/nodejs/node/commit/1c87a7e8f6)] - **doc**: add missing parenthesis in TLSSocket section (Tobias NieĆen) [#​44512](https://togithub.com/nodejs/node/pull/44512)
- \[[`05006eddb2`](https://togithub.com/nodejs/node/commit/05006eddb2)] - **doc**: do not use "Returns:" for crypto.constants (Tobias NieĆen) [#​44481](https://togithub.com/nodejs/node/pull/44481)
- \[[`54b6ed58bc`](https://togithub.com/nodejs/node/commit/54b6ed58bc)] - **doc**: use serial comma in addons docs (Tobias NieĆen) [#​44482](https://togithub.com/nodejs/node/pull/44482)
- \[[`11452a97b3`](https://togithub.com/nodejs/node/commit/11452a97b3)] - **doc**: add --update-assert-snapshot to node.1 (Colin Ihrig) [#​44429](https://togithub.com/nodejs/node/pull/44429)
- \[[`ae028e8ac3`](https://togithub.com/nodejs/node/commit/ae028e8ac3)] - **doc**: improve assert.snapshot() docs (Colin Ihrig) [#​44429](https://togithub.com/nodejs/node/pull/44429)
- \[[`71c869688a`](https://togithub.com/nodejs/node/commit/71c869688a)] - **doc**: add missing imports in events sample code (Brian Evans) [#​44337](https://togithub.com/nodejs/node/pull/44337)
- \[[`92046e8027`](https://togithub.com/nodejs/node/commit/92046e8027)] - **doc**: apply scroll-margin-top to h2, h3 elements (metonym) [#​44414](https://togithub.com/nodejs/node/pull/44414)
- \[[`3e6cde5931`](https://togithub.com/nodejs/node/commit/3e6cde5931)] - **doc**: fix spacing issue in `--build-snapshot` help text (Shohei YOSHIDA) [#​44435](https://togithub.com/nodejs/node/pull/44435)
- \[[`8e41dbb81b`](https://togithub.com/nodejs/node/commit/8e41dbb81b)] - **doc**: mention cherry-pick edge-case on release (RafaelGSS) [#​44408](https://togithub.com/nodejs/node/pull/44408)
- \[[`cef30f9afc`](https://togithub.com/nodejs/node/commit/cef30f9afc)] - **doc**: note on release guide to update `main` branch (Ruy Adorno) [#​44384](https://togithub.com/nodejs/node/pull/44384)
- \[[`21437f7a7f`](https://togithub.com/nodejs/node/commit/21437f7a7f)] - **doc**: fix release guide example consistency (Ruy Adorno) [#​44385](https://togithub.com/nodejs/node/pull/44385)
- \[[`ed52bd0a18`](https://togithub.com/nodejs/node/commit/ed52bd0a18)] - **doc**: fix style of n-api.md (theanarkh) [#​44377](https://togithub.com/nodejs/node/pull/44377)
- \[[`65c1f4015f`](https://togithub.com/nodejs/node/commit/65c1f4015f)] - **doc**: add history for net.createServer() options (Luigi Pinca) [#​44326](https://togithub.com/nodejs/node/pull/44326)
- \[[`4a0f750a6c`](https://togithub.com/nodejs/node/commit/4a0f750a6c)] - **doc**: add daeyeon to collaborators (Daeyeon Jeong) [#​44355](https://togithub.com/nodejs/node/pull/44355)
- \[[`8cc5556f76`](https://togithub.com/nodejs/node/commit/8cc5556f76)] - **doc**: fix typo in test runner code examples (Moshe Atlow) [#​44351](https://togithub.com/nodejs/node/pull/44351)
- \[[`b660b7467d`](https://togithub.com/nodejs/node/commit/b660b7467d)] - **doc,worker**: document resourceLimits overrides (Keyhan Vakil) [#​43992](https://togithub.com/nodejs/node/pull/43992)
- \[[`2ed3b30696`](https://togithub.com/nodejs/node/commit/2ed3b30696)] - **inspector**: prevent integer overflow in open() (Tobias NieĆen) [#​44367](https://togithub.com/nodejs/node/pull/44367)
- \[[`b8f08e5e7e`](
</details>
### Configuration
š
**Schedule**: Branch creation - "every weekday" (UTC), Automerge - At any time (no schedule defined).
š¦ **Automerge**: Disabled by config. Please merge this manually once you are satisfied.
ā» **Rebasing**: Whenever PR becomes conflicted, or you tick the rebase/retry checkbox.
š **Ignore**: Close this PR and you won't be reminded about this update again.
- [ ] If you want to rebase/retry this PR, check this box
This PR has been generated by [Mend Renovate](https://www.mend.io/free-developer-tools/renovate/). View repository job log [here](https://app.renovatebot.com/dashboard#github/TryGhost/Ghost).
mjw
October 29, 2022, 10:18am
3
See here for supported versions.
Thereās no guarantee, but it usually takes 1-2 weeks for the latest LTS version to be supported.
jeff
November 1, 2022, 2:50am
5
Thanks - but problem is that our mandated security policy is to apply the Node upgrade as soon as it goes Stable/LTS⦠(actually 3 days after).
We leave the Ghost instances running - using dead inodes - but clearly the lag is not good.
If there are any urgent security updates or a power cycle this may cause issues for all Ghost instances - in the worst case, all blogs offline until the pull request is merged and packaged for release.
Iāve noted this internally as a Ghost gotcha - expect Ghost instability for two weeks every October. Iāve asked - but the gods of security insist that Node upgrades take precedence over Ghost stability.
Thatās an⦠interesting security posture
jeff
November 1, 2022, 4:46am
7
Yeah :) - Weāre a bit paranoid about keeping Node and associated up-to-date given the dependency explosion. Node 18 has been in active use since April, we use it for a number of in-house apps, and this is also partly about making sure that unmaintained modules are identified soonest.
Once, many years ago (>20), forensics showed that we were about 15 minutes late in applying a patch on a late Monday morning. An active exploit defaced one of our non-critical static sites.
Never forget, never delay is now one of our maxims.
I have no qualms with this Itās just that generally new LTS versions of node wonāt be any more secure than older LTS versions - so itās more critical to be on the latest minor/patch than major (unless Iām missing something ).
nspeaks
November 15, 2022, 12:26pm
9
Been 3 weeks now. In the past Ghost added the LTS versions inside a week at max from the looks of it.
jeff
January 25, 2023, 5:04am
10
Yay - I see that Ghost added support for Node 18 sometime in early January.
Timely given this mornings CVE notice on Node security releases going out now.
Assuming the CVEs are covered in the 2023-02 security releases , all maintained versions had updates. I completely agree that vulnerable versions of software should be upgraded ASAP, but Iām still having trouble understanding how node 18 LTS is any more (or less) secure than 16 LTS.
jeff
February 20, 2023, 7:02am
12
Node is used by packages other than Ghost - they donāt always backport fixes - including CVEs - to old versions of their packages on old versions of Node.
Itās the same for most infrastructure - generally databases, web servers, operating systems, hypervisors etc. recommend you run their latest stable versions when you can.
Good infra - like Node - continue to backport to old versions - so you can pin yourself to v16 if you want to. Itās surprising to make this a policy though, and I certainly wouldnāt recommend it - but you be you
I would be very surprised if an LTS version of node did not receive a security update. The entire premise of LTS/maintenance versions is for security
To be clear, Iām not suggesting that people should use v16. Iām saying that since v16 is receiving the same security support as v18, itās wrong to imply that v16 is less secure, especially on public forums not targeting infrastructure/security people.
jeff
February 26, 2023, 11:43pm
14
Yeah - but itās not just Node itself you have to worry about - itās the entire ecosystem of dependencies - and they donāt all follow the Node cadence.
If you are pinned to a maintenance version, npm audit might be a useful check.
Ahh, I missed that part in your initial response, and thatās a great point! However, in the case of an āappā (vs library) like Ghost, it still wouldnāt make a difference since Ghostās policy is to support LTS node versions - so if a library releases a version that e.g. drops node 16 support in 2.5.0, Ghost would be pinned to e.g. 2.4.3 until node 16 is no longer LTS. If there was a security release (e.g. 2.5.3), it would be up to Ghost to either determine that staying on 2.4.3 is fine (e.g. the usage of the library in the app is such that the vulnerability canāt be exploited), or to get a version of the library with the security fix that also supports node 16.
