Ghost not starting ( Freezes in Starting Ghost )
Hello,
Recently i updated Ghost CLI, Node Version
When i am trying to start or restart ghost its not working…
Here following the information
mydemo@server91:~/public_html/etube$ ghost start
  • sudo systemctl is-active ghost_etube-demo
  • sudo systemctl reset-failed ghost_etube-demo
    :heavy_check_mark: Ensuring user is not logged in as ghost user
    :heavy_check_mark: Checking if logged in user is directory owner
    :heavy_check_mark: Validating config
    :heavy_check_mark: Checking folder permissions
    :heavy_check_mark: Checking file permissions
    :heavy_check_mark: Checking content folder ownership
  • sudo systemctl start ghost_etube-demo
    ☴ Starting Ghost
My ghost and Ghost-CLI version :
Ghost-CLI version: 1.11.0
Ghost version: 2.23.3
Node : v10.13.0
Nodejs : v6.17.1
Please help me to fix that.
Nodejs 6 is deprecated. You should use node 10.
Yes… it was nodejs issue
In my case i ran: ghost update --force
I have a similar issue at the moment and will happily start a new thread if deemed warranted.
I’ve just upgraded to node v10.16.0 after seeing @pascalandy note that version 6, which I was running, was deprecated (thanks for that pointer).
My blog was running fine until I ran ghost update to upgrade my blog to 2.25.0 (previous version was either 23 or 24, apologies, I didn’t note which). Initially the upgrade complained about the npm version but that’s sorted now.
The Ghost service isn’t running following the upgrade. Indeed, issuing ghost start says:
+ sudo systemctl start ghost_localhost
  Starting Ghost
and then just hangs.
Running ghost run allows the blog to start correctly.
System is is Debian 9.9 with Nginx serving Ghost. I note the Ghost server isn’t running hence bad gateway messages.
I’ve tried ghost update --force which completed successfully but didn’t resolve the issue.
Incidentally, if I execute ghost run the blog starts correctly.
Any advice please?
My start issue solved here:
