I recently upgraded from 2.x to 3.x but I had an issue where I got a 500 error when attempting to upload images using the admin and I decided to run updates and restart the server.
After restarting the server, ghost did not start.
When I run ghost start it hangs for a very long time with:
+ sudo systemctl is-active ghost_138-68-63-196
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
+ sudo systemctl start ghost_138-68-63-196
☴ Starting Ghost: 138-68-63-196
and eventually fails with this message:
A GhostError occurred.
Message: Could not communicate with Ghost
Suggestion: journalctl -u ghost_138-68-63-196 -n 50
OS: Ubuntu, v18.04.3 LTS
Node Version: v10.13.0
Ghost Version: 3.1.0
Ghost-CLI Version: 1.13.1
Environment: production
Command: 'ghost start'
Additional log info available in: /home/ghost-mgr/.ghost/logs/ghost-cli-debug-2019-11-30T04_46_30_099Z.log
You can always refer to https://ghost.org/docs/api/ghost-cli/ for troubleshooting.
When I run the suggested journalctl -u ghost_138-68-63-196 -n 50, this looks interesting:
(node:6625) Warning: require() of ES modules is not supported.
require() of /var/www/ghost/versions/3.1.0/node_modules/oembed-parser/index.js from /var/www/ghost/versions/3.1.0/core/server/overrides.js is an ES module file as it is a .js file whose nearest parent package.json contains "type": "module" which defines all .js files in that package scope as ES modules.
Instead rename index.js to end in .cjs, change the requiring code to use import(), or remove "type": "module" from /var/www/ghost/versions/3.1.0/node_modules/oembed-parser/package.json.
internal/modules/cjs/loader.js:1156
throw new ERR_REQUIRE_ESM(filename);
Error [ERR_REQUIRE_ESM]: Must use import to load ES Module: /var/www/ghost/versions/3.1.0/node_modules/oembed-parser/index.js
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1156:13)
at Module.load (internal/modules/cjs/loader.js:976:32)
at Function.Module._load (internal/modules/cjs/loader.js:884:14)
at Module.require (internal/modules/cjs/loader.js:1016:19)
at require (internal/modules/cjs/helpers.js:69:18)
at Object.<anonymous> (/var/www/ghost/versions/3.1.0/core/server/overrides.js:16:32)
at Module._compile (internal/modules/cjs/loader.js:1121:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1160:10)
at Function.Module._load (internal/modules/cjs/loader.js:884:14) {
code: 'ERR_REQUIRE_ESM'
ghost_138-68-63-196.service: Service hold-off time over, scheduling restart.
ghost_138-68-63-196.service: Scheduled restart job, restart counter is at 5.
Stopped Ghost systemd service for blog: 138-68-63-196.
ghost_138-68-63-196.service: Start request repeated too quickly.
ghost_138-68-63-196.service: Failed with result 'start-limit-hit'.
Failed to start Ghost systemd service for blog: 138-68-63-196.
I’m going to look into that specific oembed-parser lib, but I haven’t yet.
The odd thing is that if I run ghost run, it does start. I see the following when I do:
The `ghost run` command is used by the configured Ghost process manager and for debugging. If you're not running this to debug something, you should run `ghost start` instead.
+ sudo node current/index.js
[2019-11-30 04:53:45] INFO Ghost is running in production...
[2019-11-30 04:53:45] INFO Your site is now available on https://tumbleweird.org/
[2019-11-30 04:53:45] INFO Ctrl+C to shut down
[2019-11-30 04:53:45] WARN Can't connect to the bootstrap socket (localhost 8000) ECONNREFUSED
[2019-11-30 04:53:45] WARN Tries: 0
[2019-11-30 04:53:45] WARN Retrying...
[2019-11-30 04:53:45] WARN Tries: 1
[2019-11-30 04:53:45] WARN Tries: 2
[2019-11-30 04:53:45] INFO Ghost boot 4.615s
It did seem like that could even be related to my images uploading issue, and so while I had the server running via ghost run, I attempted to upload an image in a post and it worked perfectly. (Previously, it was spitting a 500 error when attempting to upload an image.)
Because I expect I’ll get asked, running ghost doctor gives me the following, indicating things are fine:
✔ Checking logged in user
✔ Checking operating system compatibility
+ sudo systemctl reset-failed ghost_138-68-63-196
✔ Validating config
