Ghost setup Authorization failiure
I’m trying to run Ghost with a docker image. Everything seems to be working until I run the setup, then I get the following error: Authorization failed Unable to determine the authenticated user or integration. Check that cookies are being passed through if using session authentication.
And the log says the following:
2020-06-06T21:18:55.665780000Z [2020-06-06 21:18:55] INFO Ghost is running in production…
2020-06-06T21:18:55.667902000Z [2020-06-06 21:18:55] INFO Your site is now available on https://pi-exports.com/
2020-06-06T21:18:55.679869000Z [2020-06-06 21:18:55] INFO Ctrl+C to shut down
2020-06-06T21:18:55.682375000Z [2020-06-06 21:18:55] INFO Ghost boot 2.683s
2020-06-06T21:19:17.872642000Z [2020-06-06 21:19:17] INFO “GET /ghost/” 200 102ms
2020-06-06T21:19:17.874216000Z (node:1) [DEP0066] DeprecationWarning: OutgoingMessage.prototype._headers is deprecated
2020-06-06T21:19:18.368059000Z [2020-06-06 21:19:18] INFO “GET /ghost/assets/img/favicon.ico” 200 1ms
2020-06-06T21:19:18.460012000Z [2020-06-06 21:19:18] ERROR “GET /ghost/api/v3/admin/users/me/?include=roles” 403 10ms
2020-06-06T21:19:18.460212000Z
2020-06-06T21:19:18.460342000Z Authorization failed
2020-06-06T21:19:18.460499000Z “Unable to determine the authenticated user or integration. Check that cookies are being passed through if using session authentication.”
2020-06-06T21:19:18.460687000Z Error ID:
2020-06-06T21:19:18.460772000Z 61bd1560-a83b-11ea-9103-910f814fb93b
2020-06-06T21:19:18.460912000Z ----------------------------------------
2020-06-06T21:19:18.461114000Z NoPermissionError: Authorization failed
2020-06-06T21:19:18.461195000Z at new NoPermissionError (/var/lib/ghost/versions/3.18.1/node_modules/ghost-ignition/lib/errors/index.js:134:23)
2020-06-06T21:19:18.461266000Z at authorizeAdminApi (/var/lib/ghost/versions/3.18.1/core/server/services/auth/authorize.js:28:25)
2020-06-06T21:19:18.461349000Z at Layer.handle [as handle_request] (/var/lib/ghost/versions/3.18.1/node_modules/express/lib/router/layer.js:95:5)
2020-06-06T21:19:18.461419000Z at next (/var/lib/ghost/versions/3.18.1/node_modules/express/lib/router/route.js:137:13)
2020-06-06T21:19:18.461485000Z at authenticate (/var/lib/ghost/versions/3.18.1/core/server/services/auth/session/middleware.js:24:13)
2020-06-06T21:19:18.461549000Z at processTicksAndRejections (internal/process/task_queues.js:97:5)
I remember running in to this issue before, installing ghost using ghost-cli, and I think it was local file permission problem. Does anyone have any idea what it could be?
Using latest ghost version with docker on Fedora Core OS.
It was an NGINX issue in the end. I had to add the following to the .conf file:
location ^~ /ghost/ {
inside server {}.
