Ghost was able to start, but errored during boot with: Knex: run
I’ve been trying to install Ghost on my shared server using cpanel terminal but it’s giving me the following error,
I don’t know understand what I’m doing wrong and I’ve already reinstalled it more than 5 times but I’m facing the same error always,
from my research, I think it has something to do with the GCC compiler and Ghost-CLI is not able to connect to it so help me out.
:heavy_check_mark: Checking system Node.js version - found v14.18.3
:information_source: Ensuring user is not logged in as ghost user [skipped]
:information_source: Checking if logged in user is directory owner [skipped]
:heavy_check_mark: Validating config
:heavy_check_mark: Checking binary dependencies
:heavy_multiplication_x: Starting Ghost: ghost-local
A GhostError occurred.
Message: Ghost was able to start, but errored during boot with: Knex: run
$ npm install sqlite3 --save
/lib64/libstdc++.so.6: version `CXXABI_1.3.8’ not found (required by /home/maaenter/thedistractedmonkey/versions/4.47.2/node_modules/sqlite3/lib/binding/napi-v6-linux-glibc-x64/node_sqlite3.node)
OS: unknown, vunknown
Node Version: v14.18.3
Ghost Version: 4.47.2
Ghost-CLI Version: 1.19.3
Environment: development
Command: ‘ghost start’
Additional log info available in: /home/maaenter/.ghost/logs/ghost-cli-debug-2022-05-15T12_49_15_909Z.log
I was successfully able to install Ghost 4.3.3 but for some reason whenever I try to install the latest version or update it to the latest version it gives me the same error I’ve shown above.
I have come across the same problem while doing the installation on centos7. Though I cannot confirm I think the issue is with incompatibility between centos7 and sqlite3, as mentioned in this blow.
Ghost update woes - version `CXXABI_1.3.8’ not found - Opalstack Community Forum
Did we ever find a solution to this in the community?
not really, but I successfully installed a really old version of ghost, I don’t quite remember which version, but it was pretty outdated so I just moved on.
Thanks for the reply.
From my research, I don’t think it’s possible to do either… which is a shame
