Followed the ghost installation guide for Ubuntu install (using a RaspberryPi3B+ with the official Ubuntu core image.
Aside from the ghost guide installation, I also expanded the pi volume, to use the whole SDcard, setup a root user for the server, and got NTP updated etc. (all the basic stuff, before installing ghost.)
Everything in the ghost install went smoothly and without error until the final command in ‘ghost install’ sequence (which is: start ghost? y.). It runs through all the checks and then get’s to the ‘Starting Ghost’ bit, and then fail.
subsequent attempts to start ghost give me the below output. Ghost doctor does not reveal any errors.
NB: saw this post - was failing on version of node = v8.15.1 and ghost cli = 1.9.9. I updated to node v10x, but still failing in same way.
**blog@ubuntu** : **/var/www/ghost** $ ghost start
+ sudo systemctl is-active ghost_localhost
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
+ sudo systemctl start ghost_localhost
+ sudo systemctl stop ghost_localhost
✖ Starting Ghost
A GhostError occurred.
Message: Migration lock was never released or currently a migration is running.
Help: If you are sure no migration is running, check your data and if your database is in a broken state, you could run `knex-migrator rollback`.
Suggestion: journalctl -u ghost_localhost -n 50
OS: Ubuntu, v18.04
Node Version: v8.15.1
Ghost-CLI Version: 1.9.9
Environment: production
Command: 'ghost start'
Additional log info available in: /home/blog/.ghost/logs/ghost-cli-debug-2019-03-31T01_02_41_086Z.log
Logs on node 8x:
blog@ubuntu:~$ cat /home/blog/.ghost/logs/ghost-cli-debug-2019-03-31T01_02_41_086Z.log
OS: Ubuntu, v18.04
Stack: Error: Migration lock was never released or currently a migration is running.
at Server.server.close (/usr/lib/node_modules/ghost-cli/lib/utils/port-polling.js:38:28)
at Object.onceWrapper (events.js:313:30)
at emitNone (events.js:106:13)
at Server.emit (events.js:208:7)
at emitCloseNT (net.js:1664:8)
at _combinedTickCallback (internal/process/next_tick.js:136:11)
at process._tickCallback (internal/process/next_tick.js:181:9)
Logs on node 10x
blog@ubuntu:/var/www/ghost$ cat /home/blog/.ghost/logs/ghost-cli-debug-2019-03-31T01_47_43_471Z.log
OS: Ubuntu, v18.04
Node Version: v10.15.3
at Object.onceWrapper (events.js:277:13)
at Server.emit (events.js:189:13)
at emitCloseNT (net.js:1609:8)
at process._tickCallback (internal/process/next_tick.js:63:19)
Doctor output:
**blog@ubuntu** : **/var/www/ghost** $ ghost doctor
✔ Checking logged in user
✔ Checking operating system compatibility
? **Sudo Password** *[hidden]*
+ sudo systemctl reset-failed ghost_localhost
✔ Validating config
‘ghost run’ output
blog@ubuntu:/var/www/ghost$ ghost run
The `ghost run` command is used by the configured Ghost process manager and for debugging. If you're not running this to debug something, you should run `ghost start` instead.
+ sudo node current/index.js
[2019-03-31 01:56:31] WARN Can't connect to the bootstrap socket (localhost 8000) ECONNREFUSED
[2019-03-31 01:56:31] WARN Tries: 0
[2019-03-31 01:56:31] WARN Retrying...
[2019-03-31 01:56:31] WARN Tries: 1
[2019-03-31 01:56:31] WARN Tries: 2
[2019-03-31 01:56:31] ERROR
"If you are sure no migration is running, check your data and if your database is in a broken state, you could run `knex-migrator rollback`."
Error ID:
500
MigrationsAreLockedError: Migration lock was never released or currently a migration is running.
at MigrationsAreLockedError.KnexMigrateError (/var/www/ghost/versions/2.19.1/node_modules/knex-migrator/lib/errors.js:7:26)
at new MigrationsAreLockedError (/var/www/ghost/versions/2.19.1/node_modules/knex-migrator/lib/errors.js:38:26)
at /var/www/ghost/versions/2.19.1/node_modules/knex-migrator/lib/index.js:896:23
at tryCatcher (/var/www/ghost/versions/2.19.1/node_modules/bluebird/js/release/util.js:16:23)
at Promise._settlePromiseFromHandler (/var/www/ghost/versions/2.19.1/node_modules/bluebird/js/release/promise.js:512:31)
at Promise._settlePromise (/var/www/ghost/versions/2.19.1/node_modules/bluebird/js/release/promise.js:569:18)
at Promise._settlePromise0 (/var/www/ghost/versions/2.19.1/node_modules/bluebird/js/release/promise.js:614:10)
at Promise._settlePromises (/var/www/ghost/versions/2.19.1/node_modules/bluebird/js/release/promise.js:694:18)
at _drainQueueStep (/var/www/ghost/versions/2.19.1/node_modules/bluebird/js/release/async.js:138:12)
at _drainQueue (/var/www/ghost/versions/2.19.1/node_modules/bluebird/js/release/async.js:131:9)
at Async._drainQueues (/var/www/ghost/versions/2.19.1/node_modules/bluebird/js/release/async.js:147:5)
at Immediate.Async.drainQueues [as _onImmediate] (/var/www/ghost/versions/2.19.1/node_modules/bluebird/js/release/async.js:17:14)
at runCallback (timers.js:705:18)
at tryOnImmediate (timers.js:676:5)
at processImmediate (timers.js:658:5)
