Thanks @lovecactus,
The new script keeps failing… I attach logs.
We appreciate your continued cooperation in providing logs. Once again, we have addressed the issue and updated the code. Please pull the latest version and test it out.
Should you encounter any additional issues, feel free to reach out to us.
Thanks for all @lovecactus
The script is working properly again!!! Is it due to a change in Ghost?
In the “ghost_relation_tags.py” script I have only seen this error. It generates everything correctly except those 3. I don’t know if it is normal or how I can fix it. But I just published a new article, I have run the 2 scripts and it works!
We have updated the script to address this warning.
Please update your code and give it another attempt.
This is the appropriate clean-up process. The three records in question were likely remnants of unused cache, and they should not reappear in the future.
Hi @lovecactus,
Another bug now when execute the first script “ghost_embeddings.py”
I tried to execute on another computer that i have at home and another error:
Could you please provide me with the log file located at: ./log/embedding.log? This will assist us in identifying your problem. Thank you!
Thanks @lovecactus I have sent you a PM on Ghost with the log screenshots.
Replied in PM. Please check it when you have a moment. Thank you!
Replied @lovecactus
Thanks!!
Any updates @peterwo @lovecactus ?
Thanks!!
I fixed it to work with latest openAI version. Also raised a pull request for main branch
GitHub - Rhsameera/ghostai: Harnessing AI technology with Ghost Blogging Platform that my branch with the fixes
I tested it and it works on localhost, I’m excited to ship it on production!
I modified the prompt to get prompts in a different language and added functionality for using it with external OpenAI Compatible endpoints.
Note for implementation
systemd(not secure but it’s used by Ghost) andcronare needed in order to get the scripts updating the posts.
If someone is interested I can share the code, I’m currently testing it for a few days on my beta websites.
