Heads up: Cloudflare proxying in front of Ghost Pro will break it... eventually
All,
A heads up that I’ve seen problems with several sites (including one of mine, one a client’s that I didn’t set up, and one a client’s that I did set up) in the last two weeks. All were Ghost Pro sites with custom domains, and both had Cloudflare set to “Proxy” (not “DNS only”).
It has been possible to activate a custom domain on Ghost Pro and then flip Cloudflare over to proxy. This worked when I first tried it in ~April '23, and can still be done today. (It is not possible to activate a custom domain on Ghost Pro while Cloudflare is set to proxy.)
HOWEVER, I recently found my own demo site with an invalid (expired) certificate, as did one client. (It also looked like Ghost Pro no longer thought the custom domain was valid.) Another client has new problems with the root domain not redirecting to www, that appears to be coming from Ghost Pro, although it looks like his certificate did renew recently. That site uses a Worker to do some rewriting, and it’s possible the problem is not quite the same.
On my site, the temporary solution was to turn off proxying at Cloudflare, remove and re-add the custom domain, and then turn proxying back on. I’m expecting that’ll fix the problem for 90 days, when the certificate needs to renew again.
So, the TL;DR:
  • If you’re proxying with Cloudflare and using Ghost Pro, watch your certs for expiration. I am pretty sure this is new behavior, so don’t assume that just because it’s been fine for the last year, it’s still fine.
  • If anyone knows what rewriting/pass-through at Cloudflare would allow this to work, that’d be awesome. Please share!
And yes, I know that Ghost Pro uses Fastly and that sticking a second reverse proxy in front of it sounds sort of silly, but there are good uses for user-controlled Cloudflare out in front, such as page rewriting (for custom scripts loading, added meta-data, missing localizations, IP-based access, etc etc).
Cloudflare docs on how to validate domains so SSL certs can auto renew are here:
Could someone give an update on the compatibility?
I would like to use Ghost Pro behind Cloudflare Proxy and am not sure if the issues are resolved.
This official document says:
If you’re on Ghost(Pro) both nginx and Cloudflare are configured as standard and you don’t need to do anything.
So, if I understand this correctly, Ghost Pro should not have any issues with Cloudflare at the moment.
More details
I think the issue Cathy noticed here is about how Ghost Pro issues their SSL certificates. Probably, Cloudflare’s SSL generation mechanism was conflicting with Ghost Pro’s way, at that time.
In addition to that, Cloudflare uses “Flexible SSL mode” by default, which comes to your target url with http address even if your visitor comes to Cloudflare with https. If Ghost Pro automatically redirects those requests to https protocols (as I do in Synaps Media), then this causes redirect loop. Because of that, I suggest using “Full SSL mode” in Cloudflare for my customers in Synaps Media. Same could apply for Ghost Pro. Better to ask Ghost Pro support directly. More on this: ERR_TOO_MANY_REDIRECTS · Cloudflare SSL/TLS docs
I might have just had something similar happen to me. I’m not sure how to tell if I was just issued a new certificate, but turning my A and CNAME records from Proxied → DNS Only and then back to Proxied again seemed to fix it.
I know this is an old thread, but it’s what came up in a google search for the 525 error I was getting. If it was caused by an expired certificate issue as @Cathy_Sarisky mentioned, Cloudflare now has an function (in Beta) where you can get an email whenever a new certificate is issued.
The jargon in Cloudflare isn’t something I’m fluent in, so this might not be supportive. But just in case it is…
Within your domain, in Cloudflare to go SSL/TLS → Edge Certificates → Certificate Transparency Monitoring: Receive an email when a Certificate Authority issues a certificate for your domain.
