A client’s substack migration had posts with /p/post-name. I wrote a regex redirect rule to /postname/ and thought the problem was fixed.
And then, today he tried to preview a post, and got a 404. Apparently the post preview names those unpublished posts /p/uuid , which then redirects them, which breaks the preview.
So… I’ll file a Github issue, because the preview probably should ignore the redirects file. But meanwhile, if anyone has a suggestion that doesn’t involve writing 100 individual redirects into redirects.yaml, I’d be most appreciative.
(This post makes finding the problem sound a LOT simpler than it actually was. That’s an hour of my life I’m not getting back!!)
Previews are built deeply into the frontend with a hardcoded url of /p/:uuid/ as you discovered. You’re right they probably should ignore redirects, but changing that would be significant and is unlikely to happen outside of a huge rewrite of the frontend.
The best solution I can think of is to use a regex match for /p/ followed by not-a-uuid as they have a very specific structure.
I asked ChatGPT to write this regex, and it gave me this:
