Help me ,Some problems
I meet some problems when I installing ghost.
I need help!
Thank you!
ghost install local
√ Checking system Node.js version
√ Checking current folder permissions
√ Checking memory availability
√ Checking for latest Ghost version
√ Setting up install directorystall local
√ Downloading and installing Ghost v3.24.0
√ Finishing install process
√ Configuring Ghost
√ Setting up instance
× Starting Ghost
One or more errors occurred.
  1. GhostError
Message:
D:\NodeProject\myGhost\versions\3.24.0\node_modules\knex\lib\client.js:236
throw new Error(${message}\n${e.message});
Error: Knex: run
$ npm install sqlite3 --save
Cannot find module ‘sqlite3’
Require stack:
  • D:\NodeProject\myGhost\versions\3.24.0\node_modules\knex\lib\dialects\sqlite3\index.js
  • D:\NodeProject\myGhost\versions\3.24.0\node_modules\knex\lib\knex.js
  • D:\NodeProject\myGhost\versions\3.24.0\node_modules\knex\lib\index.js
  • D:\NodeProject\myGhost\versions\3.24.0\node_modules\knex\knex.js
  • D:\NodeProject\myGhost\versions\3.24.0\core\server\data\db\connection.js
  • D:\NodeProject\myGhost\versions\3.24.0\core\server\index.js
  • D:\NodeProject\myGhost\versions\3.24.0\core\index.js
  • D:\NodeProject\myGhost\versions\3.24.0\index.js
    at Client_SQLite3.initializeDriver (D:\NodeProject\myGhost\versions\3.24.0\node_modules\knex\lib\client.js:236:13)
    at Client_SQLite3.Client (D:\NodeProject\myGhost\versions\3.24.0\node_modules\knex\lib\client.js:70:10)
    at new Client_SQLite3 (D:\NodeProject\myGhost\versions\3.24.0\node_modules\knex\lib\dialects\sqlite3\index.js:18:10)
    at Knex (D:\NodeProject\myGhost\versions\3.24.0\node_modules\knex\lib\knex.js:53:28)
    at Object. (D:\NodeProject\myGhost\versions\3.24.0\core\server\data\db\connection.js:34:20)
    at Module._compile (internal/modules/cjs/loader.js:1138:30)
    at Object.Module._extensions…js (internal/modules/cjs/loader.js:1158:10)
    at Module.load (internal/modules/cjs/loader.js:986:32)
    at Function.Module._load (internal/modules/cjs/loader.js:879:14)
    at Module.require (internal/modules/cjs/loader.js:1026:19)
    at require (internal/modules/cjs/helpers.js:72:18)
    at isDatabaseInitialisationRequired (D:\NodeProject\myGhost\versions\3.24.0\core\server\index.js:163:16)
    at makeGhost (D:\NodeProject\myGhost\versions\3.24.0\core\index.js:13:12)
    at Object. (D:\NodeProject\myGhost\versions\3.24.0\index.js:27:1)
    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:71:12)
    at internal/main/run_main_module.js:17:47
OS: Microsoft Windows 10 רҵ��, v10.0.19041
Node Version: v12.18.2
Ghost Version: 3.24.0
Ghost-CLI Version: 1.14.1
Environment: development
Command: ‘ghost install local’
The problem seems to be with the database, but wasn’t it fully configured during installation?
Asking for your help.Thank you!
D:\NodeProject\myGhost>ghost start
Found a development config but not a production config, running in development mode instead
√ Validating config
√ Checking binary dependencies
× Starting Ghost: ghost-local
A GhostError occurred.
Message:
internal/modules/cjs/loader.js:969
throw err;
Error: Cannot find module ‘D:\NodeProject\myGhost\current\index.js’
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:966:15)
at Function.Module._load (internal/modules/cjs/loader.js:842:27)
at internal/main/run_main_module.js:17:47 {
code: ‘MODULE_NOT_FOUND’,
requireStack:
D:\NodeProject\myGhost>ghost doctor
√ Validating config
