Help with dynamic routing
Dear Ghosters.!
It’s my first Ghost setup, and i love it.!
Really fast and amazingly easy to work with.
I started customize the Editorial theme to my likeings but the past 24 hours i have tried to get the dynamic routing to work propperly.
I have a few custom pages.
/ (index) - Currently just the index.hbs from the theme.
/blog - uses blog.hbs and shows posts with tag Blog
/projects - uses projects.hbs and shows posts with Projects tag
/about - uses about.hbs
/contact - uses contact.hbs
But my problem is that my posts url’s should be at “site.com/blog/story1” and “site.com/projects/bigproject1” but they are currently on “site.com/story1”
My routes.yaml looks like this
routes:
  /about/:
    data: page.about
    template: about
  /contact/:
    data: page.contact
    template: contact
collections:
    permalink: /{slug}/
    template: index
  /blog/:
    permalink: /blog/{slug}/
    template: blog
    filter: tag:Blog
  /projects/:
    permalink: /projects/{slug}/
    template: projects
    filter: tag:Projects
taxonomies:
Does anyone know what i’m doing wrong here?
Best regards
Henrik
Posts can only live in one collection. Collections are iterated over and “collect” posts. Your first collection has no filter, so it “collects” all the posts. To fix this you need to make your filters explicit with inverse filters:
Hi Hannah,
Thank you for your reply.
The inverted filters had no effect on my problem.
Still on “site.com/blog” it shows all blog posts, but im redirected to “site.com/blogpost” and not “site.com/blog/blogpost”
Updated routes.yaml
routes:
  /about/:
    data: page.about
    template: about
  /contact/:
    data: page.contact
    template: contact
collections:
    permalink: /{slug}/
    template: index
    filter: tag:-[Blog,Projects]
  /blog/:
    template: blog
    filter: tag:Blog
  /projects/:
    template: projects
taxonomies:
I’m running Version 3.11.0
Oh sh**, i must be so tired :slight_smile:
I managed to use uppercase letters for blog and projects tag slugs.
After corrected to lowercase it all works just fine…
Thank you for your help and time.
