I have MERN stack app running with nginx configuration. I am planning to add /blog location block in nginx config and expose ghost blog for /blog location.
Nginx config:
location /blog {
proxy_pass http://localhost:2368;
Is this configuration ok? or do I need to add something else to make sure everything works and optimized? Any suggestions??
In both the articles I see this https://<yoursubdomain>.ghost.io; in my case I only want to enable ghost blog on /blog route so I can ignore https://<yoursubdomain>.ghost.io; subdomain part is that correct?
mjw
November 17, 2022, 1:53pm
5
The second article does what you require, and the first is there for context.
Did you read the documentation?
location /blog/ {
client_max_body_size 10G; # Required for uploading large files
This solution worked for me:
location ^~ /blog {
Note in config.production.json file:
replace "url":"http://localhost:2368/" with
"url": "https://yourapp.com/blog",
Some reference links:
How install Ghost in a subfolder
How to install Ghost in a subdirectory with Nginx? (Getting 404) - Stack Overflow
