There’s a quote often used in productivity circles that says, “Slow is smooth, smooth is fast.” The meaning is simple: when you go slow, you tend to make fewer mistakes. You listen better, become more observant, and save yourself the trouble of needing to start over.
Ultimately, going slow is the fastest way to reach your goals. Now, let’s help you make that patience less painful.
In this week’s issue:
- Timeline. See the average length of time it takes new creators to start getting tract
🏃♀️ How to speed up your success as a creator
