How to use it specifically, can you elaborate?
Converting HTML
The easiest way to convert HTML to mobiledoc is to generate a Ghost JSON file with html fields containing your content for each post instead of mobiledoc . You can then use Ghost’s standalone migration tool to convert the html field to a mobiledoc field.
- Requires Node.js v10 installed locally
npm install @tryghost/migrate -g- install the migration toolingmigrate json html /path/to/your/import.json- will convert the HTML fields in your JSON file- The tool will output a path to a converted JSON file - use this to import your content
- Run
npm uninstall @tryghost/migrate -gto cleanup
This should work well for most semantic HTML, and result in a series of populated cards in the editor, making it easy to update your content in future.
