What’s your URL? This is the easiest way for others to help you.
answer : https://suksesbersamakerabat.com -
What version of Ghost are you using? If it’s not the latest, please update Ghost first before opening your topic.
answer : image ghost last version
And
answer : via docker aapanel -
answer : node v.20, mysql v.8.0, ubuntu 22.04LTS with aaPanel. -
answer : I have changed the canonical in the config.production.json file to canonical https www but it still displays http www on my ghost. -
answer : I have tried to reinstall my ghost and set the url directly https www on the ghost template in docker, but it doesn’t work.
then I reinstalled it again with the url http no problem and after the reinstallation process was complete I tried to change the config.production.json file to https but the canonical that appears is still http.
because I need the canonical https www to make my SEO run easier.
is there a solution to solve the problem I’m facing?
Because my client’s website already uses aaPanel as its base and I want them to try using ghost to make their company’s SEO easier.
and I use the reverse proxy method on the domain to localhost port 8080 where my ghost is installed via docker.
Thank you.
