What version of Ghost are you using? 3.42.0
What configuration? docker rootless, Caddy Proxy
What browser? Chromium
[2021-03-09 16:06:28] ERROR “GET /content/images/size/w1000/2020/11/inwertersmart-girl-1666678.jpg” 500 7ms
Failed to lookup view “error-404” in views directory “/var/lib/ghost/versions/3.42.0/core/server/views/”
Error: Failed to lookup view “error-404” in views directory “/var/lib/ghost/versions/3.42.0/core/server/views/”
at Function.render (/var/lib/ghost/versions/3.42.0/node_modules/express/lib/application.js:580:17)
at ServerResponse.render (/var/lib/ghost/versions/3.42.0/node_modules/express/lib/response.js:1012:7)
at _private.ThemeErrorRenderer (/var/lib/ghost/versions/3.42.0/core/server/web/shared/middlewares/error-handler.js:190:9)
at Layer.handle_error (/var/lib/ghost/versions/3.42.0/node_modules/express/lib/router/layer.js:71:5)
at trim_prefix (/var/lib/ghost/versions/3.42.0/node_modules/express/lib/router/index.js:315:13)
at /var/lib/ghost/versions/3.42.0/node_modules/express/lib/router/index.js:284:7
at Function.process_params (/var/lib/ghost/versions/3.42.0/node_modules/express/lib/router/index.js:335:12)
at next (/var/lib/ghost/versions/3.42.0/node_modules/express/lib/router/index.js:275:10)
at Layer.handle_error (/var/lib/ghost/versions/3.42.0/node_modules/express/lib/router/layer.js:67:12)
at _private.prepareError (/var/lib/ghost/versions/3.42.0/core/server/web/shared/middlewares/error-handler.js:72:5)
at trim_prefix (/var/lib/ghost/versions/3.42.0/node_modules/express/lib/router/index.js:315:13)[2021-03-08 22:01:53] WARN {{#get}} helper took 342ms to complete {{#get}} helper took 342ms to complete Error ID: e447fda0-8059-11eb-96c4-cbe6c8cc375e Error Code: SLOW_GET_HELPER Details: api: v3.postsPublic.browse apiOptions: include: authors,tags limit: 3 returnedRows: 3 -
- Ubuntu 20.04
- docker rootless
- docker compose
- copy images to ghost/content/images/
*export/import from Wordpress to Ghost
While editing the post, path to the image URL is correct there, but still the image is not found.
I also uploaded featured image manually on post and the image has been uploaded and displayed correctly on the post-edit page, but it was not in /content/images directory and not displayed on frontend post.
docker-compose ghost settings:
ghost:
container_name: ghost
image: ghost:3.42.0
restart: unless-stopped
depends_on:
- mysql
environment:
NODE_ENV: production
url: https://example.com
volumes:
- ./ghostcms/content:/var/lib/ghost/content
- ./ghostcms/config.production.json:/var/lib/ghost/config.production.json
config file:
"url": "https://example.com",
"server": {
"port": 2351,
"host": "10.5.0.6"
"database": {
"client": "mysql",
"connection": {
"host": "10.5.0.7",
"port": 3306,
"user": "$user",
"password": "$password",
"database": "$databasename",
"charset": "utf8mb4"
"mail": {
"transport": "SMTP",
"options": {
"service": "$service",
"host": "$host",
"port": 587,
"secureConnection": true,
"auth": {
"user": "$user",
"pass": "$pass"
"privacy": {
"useUpdateCheck": false,
"useGravatar": false
