Hi, I’m trying to make the post a little wider because I see wasted space on every side.
I’m using the EDITION theme.
I tried to modify the Header code under Settings > Code Injection > Site Header like this:
<link rel="stylesheet" href="https://cdnjs.cloudflare.com/ajax/libs/font-awesome/6.2.0/css/brands.min.css" integrity="sha512-+oRH6u1nDGSm3hH8poU85YFIVTdSnS2f+texdPGrURaJh8hzmhMiZrQth6l56P4ZQmxeZzd2DqVEMqQoJ8J89A==" crossorigin="anonymous" referrerpolicy="no-referrer" />
<style>
.gh-head-menu .nav-twitter a {
font-size: 0 !important;
.gh-head-menu .nav-twitter a::before {
font-family: "Font Awesome 6 Brands";
display: inline-block;
font-size: 20px;
font-style: normal;
font-weight: normal;
font-variant: normal;
text-rendering: auto;
-webkit-font-smoothing: antialiased;
.gh-head-menu .nav-twitter a::before {content: "\f099"}
@media (min-width: 992px) {
.col-lg-6 {
flex: 0 0 85% !important;
max-width: 85% !important;
</style>
with no luck
Any hints on what I’m doing wrong?
Thanks,
new
May 22, 2023, 12:17pm
2
Hey there!
I can suggest you this solution which worked for me by @Cathy_Sarisky but it may differ by theme:
The Ghost editor does what it’s going to do. It isn’t intended to be a 100% WYSIWYG (what you see is what you get) representation of how the post will look, because each theme does things differently.
If you’re not getting what you want on the website (NOT in the editor), you’re going to need to adjust the theme or use some code injections. Solo uses a grid layout. I’d try this:
@media (max-width: 991px)
.gh-canvas>* {
grid-column: 2/span 10 !important;
.gh-canvas>* {
grid-column:…
Edition likely needs different code injection. Thanks for the tag - let me see if I can help you with this.
In your code injection header (find that under settings):
<style>
.gh-canvas {
grid-template-columns: [full-start] minmax(var(--gap),auto) [wide-start] minmax(auto,calc((var(--container-width, 1200px) - var(--content-width, 720px))/2)) [main-start] min(var(--content-width,720px),calc(100% - var(--gap)*2)) [main-end] minmax(auto,calc((var(--container-width, 1200px) - var(--content-width, 720px))/2)) [wide-end] minmax(var(--gap),auto) [full-end] !important;
</style>
Change all instances of 720px above to your desired width.
M_Now
March 7, 2025, 4:35pm
5
Cathy_Sarisky’s suggestion worked. I increased from 720 to 1020px and it worked for my req. thanks again
hi @Cathy_Sarisky , any chance you can help me. I have been trying to increase the width of the text in a page with Flair theme, but I am stuck. cant figure it out. Any idea? thanks in advance
Your theme uses a variable for content width. Try this, in code injection.
<style>
body {
--content-width: 800px;
</style>
(Of course, you can play with the width setting to get it just as you like it.
M_user
November 21, 2025, 2:02pm
8
Hi Cathy,
I’m new here and I’m using the Casper theme. I used your code in the injection panel and works great. Is there a way to increase the space only for one side of the page and keep a fixed space on the other one?
For exemple letting the text have more room on the right and keep a space for a navigation bar on the left.
Thank you!
Casper uses a grid (like many Ghost themes). The rules for that grid look like this:
.gh-canvas, .kg-width-full.kg-content-wide {
--gap: max(4vmin, 20px);
--main: min(var(--content-width, 720px), 100% - var(--gap) * 2);
--wide: minmax(0, calc((var(--container-width, 1200px) - var(--content-width, 720px)) / 2));
--full: minmax(var(--gap), 1fr);
display: grid;
grid-template-columns: [full-start] var(--full) [wide-start] var(--wide) [main-start] var(--main) [main-end] var(--wide) [wide-end] var(--full) [full-end];
To skew that, you’d need to change the grid-template-columns definition to pass something different for full and/or wide on the left and right sides.
It’s just math, but it’s more math than I can do for you today on the forum.
You’ll also need to think a little bit about what happens with the navigation bar on mobile.
M_user
November 28, 2025, 10:39am
10
I will try some tweaks here and there to see how it works.
Thanks Cathy!
