Manel
July 23, 2024, 2:10pm
1
Hello, I would like to insert a table inside an article (inline with text). I have been checking the edit cards available in Ghost and I can’t find any to create a table.
I attach an image with an example:
How could I achieve this result in Ghost? Any recommendations or useful resources?
Start here. @BruceInLouisville offered some great advice.
I tried embedding a table using “raw HTML card”. I used code injection to style it. However, Ghost already has predefined table styles and they affect my table.
I didn’t see any tables in Ghost, but the styles are there. What will be affected if I change native styles?
Are there any easier options?
Manel
July 23, 2024, 3:56pm
3
Thanks, I found this table generator with styles that does a good job: Table Generator | Graphical Editor
