Currently have Ghost 4.4.0 running on OpenBSD 7.0. In the 7.1 release node finally was updated from v12, to v16. I am facing a slew of errors when attempting to upgrade, or install a new local copy of the latest ghost. Any help in troubleshooting to get the latest up and running would be super appreciated!
Here is the entire output i get when attempting an install:
$ ghost install local
☱ Inspecting operating systemhostname: unknown option -- f
usage: hostname [-s] [name-of-host]
Found a development config but not a production config, running in development mode instead
Love open source? We’re hiring Node.js Engineers to work on Ghost full-time.
https://careers.ghost.org/product-engineer-node-js
✔ Checking system Node.js version - found v16.14.2
✔ Checking free space
✔ Setting up install directory
✖ Downloading and installing Ghost v4.45.0
A ProcessError occurred.
warning ../../../package.json: No license field
warning ghost@4.45.0: The engine "cli" appears to be invalid.
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@^2.29.1"
warning Resolution field "moment-timezone@0.5.23" is incompatible with requested version "moment-timezone@^0.5.33"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@^2.27.0"
warning Resolution field "moment-timezone@0.5.23" is incompatible with requested version "moment-timezone@^0.5.31"
warning Resolution field "moment-timezone@0.5.23" is incompatible with requested version "moment-timezone@^0.5.34"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@^2.29.3"
warning Resolution field "moment@2.24.0" is incompatible with requested version "moment@2.27.0"
warning Resolution field "@tryghost/logging@2.1.5" is incompatible with requested version "@tryghost/logging@2.1.7"
warning " > bookshelf@1.2.0" has incorrect peer dependency "knex@>=0.15.0 <0.22.0".
warning Error running install script for optional dependency: "/var/www/ghost/test.com/versions/4.45.0/node_modules/sharp: Command failed.
Exit code: 1
Command: (node install/libvips && node install/dll-copy && prebuild-install) || (node install/can-compile && node-gyp rebuild && node install/dll-copy)
Arguments:
Directory: /var/www/ghost/test.com/versions/4.45.0/node_modules/sharp
Output:
sharp: Installation error: BSD/SunOS systems require manual installation of libvips >= 8.12.2
sharp: Please see LINK for required dependencies"
error /var/www/ghost/test.com/versions/4.45.0/node_modules/re2: Command failed.
Exit code: 1
Command: install-from-cache --artifact build/Release/re2.node --host-var RE2_DOWNLOAD_MIRROR --skip-path-var RE2_DOWNLOAD_SKIP_PATH --skip-ver-var RE2_DOWNLOAD_SKIP_VER || npm run rebuild
Arguments:
Directory: /var/www/ghost/test.com/versions/4.45.0/node_modules/re2
Output:
Trying LINK/openbsd-x64-93.br ...
Trying LINK/openbsd-x64-93.gz ...
Building locally ...
> re2@1.17.4 rebuild
> node-gyp rebuild
gyp info it worked if it ends with ok
gyp info using node-gyp@8.4.1
gyp info using node@16.14.2 | openbsd | x64
gyp info find Python using Python version 3.9.12 found at "/usr/local/bin/python3"
gyp info spawn /usr/local/bin/python3
gyp info spawn args [
gyp info spawn args '/var/www/ghost/test.com/versions/4.45.0/node_modules/node-gyp/gyp/gyp_main.py',
gyp info spawn args 'binding.gyp',
gyp info spawn args '-f',
gyp info spawn args 'make',
gyp info spawn args '-I',
gyp info spawn args '/var/www/ghost/test.com/versions/4.45.0/node_modules/re2/build/config.gypi',
gyp info spawn args '/var/www/ghost/test.com/versions/4.45.0/node_modules/node-gyp/addon.gypi',
gyp info spawn args '/var/www/ghost/.cache/node-gyp/16.14.2/include/node/common.gypi',
gyp info spawn args '-Dlibrary=shared_library',
gyp info spawn args '-Dvisibility=default',
gyp info spawn args '-Dnode_root_dir=/var/www/ghost/.cache/node-gyp/16.14.2',
gyp info spawn args '-Dnode_gyp_dir=/var/www/ghost/test.com/versions/4.45.0/node_modules/node-gyp',
gyp info spawn args '-Dnode_lib_file=/var/www/ghost/.cache/node-gyp/16.14.2/<(target_arch)/node.lib',
gyp info spawn args '-Dmodule_root_dir=/var/www/ghost/test.com/versions/4.45.0/node_modules/re2',
gyp info spawn args '-Dnode_engine=v8',
gyp info spawn args '--depth=.',
gyp info spawn args '--no-parallel',
gyp info spawn args '--generator-output',
gyp info spawn args 'build',
gyp info spawn args '-Goutput_dir=.'
gyp info spawn args ]
gypgmake: Entering directory '/var/www/ghost/test.com/versions/4.45.0/node_modules/re2/build'
info spawn gmake
gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
CXX(target) Release/obj.target/re2/lib/addon.o
gmake: g++: No such file or directory
gmake: *** [re2.target.mk:168: Release/obj.target/re2/lib/addon.o] Error 127
gmake: Leaving directory '/var/www/ghost/test.com/versions/4.45.0/node_modules/re2/build'
gyp ERR! build error
gyp ERR! stack Error: `gmake` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/var/www/ghost/test.com/versions/4.45.0/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack at ChildProcess.emit (node:events:526:28)
gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
gyp ERR! System OpenBSD 7.1
gyp ERR! command "/usr/local/bin/node" "/var/www/ghost/test.com/versions/4.45.0/node_modules/re2/node_modules/.bin/node-gyp" "rebuild"
gyp ERR! cwd /var/www/ghost/test.com/versions/4.45.0/node_modules/re2
gyp ERR! node -v v16.14.2
gyp ERR! node-gyp -v v8.4.1
gyp ERR! not ok
node:internal/process/promises:279
triggerUncaughtException(err, true /* fromPromise */);
[UnhandledPromiseRejection: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason "1".] {
code: 'ERR_UNHANDLED_REJECTION'
> re2@1.17.4 rebuild
> node-gyp rebuild
gyp info spawn gmake
gyp info spawn argsgmake: Entering directory '/var/www/ghost/test.com/versions/4.45.0/node_modules/re2/build'
gyp ERR! not ok
warning Error running install script for optional dependency: "/var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3: Command failed.
Exit code: 1
Command: node-pre-gyp install --fallback-to-build
Arguments:
Directory: /var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3
Output:
node-pre-gyp info it worked if it ends with ok
node-pre-gyp info using node-pre-gyp@1.0.9
node-pre-gyp info using node@16.14.2 | openbsd | x64
node-pre-gyp info check checked for \"/var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3/lib/binding/napi-v6-openbsd-unknown-x64/node_sqlite3.node\" (not found)
node-pre-gyp http GET https://github.com/TryGhost/node-sqlite3/releases/download/v5.0.5/napi-v6-openbsd-unknown-x64.tar.gz
node-pre-gyp ERR! install response status 404 Not Found on LINK/napi-v6-openbsd-unknown-x64.tar.gz
node-pre-gyp WARN Pre-built binaries not installable for sqlite3@5.0.5 and node@16.14.2 (node-v93 ABI, unknown) (falling back to source compile with node-gyp)
node-pre-gyp WARN Hit error response status 404 Not Found on LINK/napi-v6-openbsd-unknown-x64.tar.gz
gyp info ok
gyp info find Python using Python version 3.9.12 found at \"/usr/local/bin/python3\"
gyp info spawn args '/var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3/build/config.gypi',
gyp info spawn args '-Dmodule_root_dir=/var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3',
gyp info ok
gmake: Entering directory '/var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3/build'
CC(target) Release/obj.target/nothing/../node-addon-api/nothing.o
AR(target) Release/obj.target/../node-addon-api/nothing.a
COPY Release/nothing.a
ACTION deps_sqlite3_gyp_action_before_build_target_unpack_sqlite_dep Release/obj/gen/sqlite-autoconf-3380200/sqlite3.c
TOUCH Release/obj.target/deps/action_before_build.stamp
CC(target) Release/obj.target/sqlite3/gen/sqlite-autoconf-3380200/sqlite3.o
AR(target) Release/obj.target/deps/sqlite3.a
COPY Release/sqlite3.a
CXX(target) Release/obj.target/node_sqlite3/src/backup.o
gmake: *** [node_sqlite3.target.mk:138: Release/obj.target/node_sqlite3/src/backup.o] Error 127
gmake: Leaving directory '/var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3/build'
gyp ERR! command \"/usr/local/bin/node\" \"/var/www/ghost/test.com/versions/4.45.0/node_modules/node-gyp/bin/node-gyp.js\" \"build\" \"--fallback-to-build\" \"--module=/var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3/lib/binding/napi-v6-openbsd-unknown-x64/node_sqlite3.node\" \"--module_name=node_sqlite3\" \"--module_path=/var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3/lib/binding/napi-v6-openbsd-unknown-x64\" \"--napi_version=8\" \"--node_abi_napi=napi\" \"--napi_build_version=6\" \"--node_napi_label=napi-v6\"
gyp ERR! cwd /var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /var/www/ghost/test.com/versions/4.45.0/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3/lib/binding/napi-v6-openbsd-unknown-x64/node_sqlite3.node --module_name=node_sqlite3 --module_path=/var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3/lib/binding/napi-v6-openbsd-unknown-x64 --napi_version=8 --node_abi_napi=napi --napi_build_version=6 --node_napi_label=napi-v6' (1)
node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/var/www/ghost/test.com/versions/4.45.0/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
node-pre-gyp ERR! stack at ChildProcess.emit (node:events:526:28)
node-pre-gyp ERR! stack at maybeClose (node:internal/child_process:1092:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:302:5)
node-pre-gyp ERR! System OpenBSD 7.1
node-pre-gyp ERR! command \"/usr/local/bin/node\" \"/var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3/node_modules/.bin/node-pre-gyp\" \"install\" \"--fallback-to-build\"
node-pre-gyp ERR! cwd /var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3
node-pre-gyp ERR! node -v v16.14.2
node-pre-gyp ERR! node-pre-gyp -v v1.0.9
node-pre-gyp ERR! not ok
Failed to execute '/usr/local/bin/node /var/www/ghost/test.com/versions/4.45.0/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3/lib/binding/napi-v6-openbsd-unknown-x64/node_sqlite3.node --module_name=node_sqlite3 --module_path=/var/www/ghost/test.com/versions/4.45.0/node_modules/sqlite3/lib/binding/napi-v6-openbsd-unknown-x64 --napi_version=8 --node_abi_napi=napi --napi_build_version=6 --node_napi_label=napi-v6' (1)"
yarn install v1.22.15
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
info fsevents@2.3.2: The platform "openbsd" is incompatible with this module.
info "fsevents@2.3.2" is an optional dependency and failed compatibility check. Excluding it from installation.
[4/5] Linking dependencies...
[5/5] Building fresh packages...
info This module is OPTIONAL, you can safely ignore this error
info Visit LINK for documentation about this command.
Exit code: 1
OS: , v
Node Version: v16.14.2
Ghost-CLI Version: 1.19.3
Environment: development
Command: 'ghost install local'
Additional log info available in: /var/www/ghost/.ghost/logs/ghost-cli-debug-2022-04-23T01_32_12_313Z.log
