I’m trying to integrate my Spring boot application with Ghost. I would like to authenticate logged in Ghost user in my app (check if present in my database). Is this possible and how can it be done? Another problem is how the user logs out of my application, Is these user still logged in to Ghost or not?
I will be very grateful for any hints or ideas.
Hi @daria, can I ask what you’re trying to do with Ghost? The integration you’re speaking of sounds rather complex and Ghost might be the right solution for what you’re trying to make
thank you very much for the answer! I decided to change strategy, I was not the best idea, it could be quite tough to figure out.
