Hi ![]()
Is it possible to customize the tipping function to look like the floating coffee cup that you get with Buymeacoffee?
I think that having a floating coffee icon on the bottom right of the page would look better/get better results.
Hi ![]()
If you Google “floating button css” you’ll likely find some options that’ll work in ghost. Then you just add your tipping link and you’re good to go!
