Is there a way to remove /tag from url?
Version ghost:1.22.4
Hello,
Currently if you’d like to see all posts of a certain tag you’d have to go to myblog.com/tag/interesting-tag. Is there a way to remove the second slash and make the tag filter url structure look like: myblog.com/interesting-tag?
Thank you!
A couple of solutions:
  1. Modify the routes.yaml so it looks like this:
    routes:
    collections:
    permalink: /{slug}/
    template:
    - index
    taxonomies:
    tag: /{slug}/
    author: /author/{slug}/
This would affect all tags and /tag/ urls may not work any more.
  1. Put something like this in the redirects.json:
    “from”: “^\/interesting-tag(\/?)$”,
    “to”: “/tag/interesting-tag/”
This will just redirect /interseting-tag to /tag/interesting-tag
https://docs.ghost.org/docs/dynamic-routing
https://docs.ghost.org/docs/redirects
This is excellent. Thank you for the knowledge bomb!
You are welcome :slight_smile:
The docs say to add this to “content/settings/routes.yaml”
Where is this folder? Within the theme or ghost app itself?
If you go to “labs” in the sidebar there is an option to upload it directly at the bottom.
