After updating Ghost to 5.30, my site and dashboard hosted with Digital Ocean crashed and ended up with a Bad Gateway 502 error. Then after using Powercycle, rebooting, and using a backed up version of the droplet, I managed to get it to work again. But then after again updating it, the same error occurred. Also when trying to restart Ghost by using ghost restart, it took very long and then came up an error message:
✖ Starting Ghost
A GhostError occurred.
Message: Could not communicate with Ghost
Suggestion: journalctl -u ghost_www-datainwonderland-com -n 50
I did use the suggested code snippet and ended up receiving the following message:
Hint: You are currently not seeing messages from other users and the system.
Users in groups 'adm', 'systemd-journal' can see all messages.
Pass -q to turn off this notice.
-- No entries --
@thimiraonline I just ran ghost doctor and got the following result:
✔ Checking system Node.js version - found v16.17.0
✔ Checking logged in user
+ sudo systemctl is-active ghost_www-datainwonderland-com
+ sudo systemctl reset-failed ghost_www-datainwonderland-com
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking free space
✔ Checking systemd unit file
✔ Checking systemd node version - found v16.17.0
But when I go back to my site I still see the same error page.
I just ran the function and got the following result in return:
? Do you want to start Ghost? Yes
+ sudo systemctl start ghost_www-datainwonderland-com
+ sudo systemctl stop ghost_www-datainwonderland-com
✖ Starting Ghost
One or more errors occurred.
1) GhostError
OS: Ubuntu, v22.04.1 LTS
Node Version: v16.17.0
Ghost Version: 5.30.1
Ghost-CLI Version: 1.24.0
Environment: production
Command: 'ghost setup'
Additional log info available in: /home/ghost-mgr/.ghost/logs/ghost-cli-debug-2023-01-19T18_05_40_941Z.log
ghost-mgr@data-wonderland:/var/www/ghost$ journalctl -u ghost_www-datainwonderland-com -n 50
-- No entries --
or else if I can have remote desktop login through Anydesk or team viewer, I coukd check what happened. Anyway, I wish you will get a help from another one at here. Have a nice day.
