LetsEncrypt SSL cert for domain and subdomain
I’ve just set up a Ghost instance on a DigitalOcean droplet for the URL https://divide100k.com. I also need https://www.divide100k.com to work, but the command ghost setup nginx ssl is only requestinf an SSL certificate for the basic URL.
As a workaround, I just modified the command and re-ran it:
sudo /etc/letsencrypt/acme.sh --issue --home /etc/letsencrypt --domain divide100k.com,www.divide100k.com --webroot /var/www/divide100/system/nginx-root --reloadcmd "nginx -s reload" --accountemail ...@gmail.com --force
That worked just fine, but I’d rather not have to make a renewal cron of an ugly hack. Is there a Ghost setting I haven’t been able to find for requesting a multi-domain cert?
Have you seen this?
I have not—that answers it, thank you!
