Mail setup problem signup/login
Dear Support-Community,
I am right now building my own Ghost blog based on the DigitalOcean Ghost-1-Click installation:
URL: https://www.tischer.io
Ghost version: 3.13.4
I used Mailgun for the setup within Ghost and in the confi.production.json
When I try to signup here https://www.tischer.io/signup/ I get: “When Please enter a valid email address!”.
When I try to send a new email for a post this works perfectly fine.
Is there anything I missed?
Thank you and warm regards
Sebastian
try to check log from command ghost log in your droplets, because this response code 500 : internal server error
Not sure what your config is like, but this is mine (taken out auth details).
"mail": {
  "transport": "SMTP",
  "options": {
    "service": "Mailgun",
    "host": "smtp.eu.mailgun.org",
    "port": 465,
    "secureConnection": true,
    "auth": {
      "user": "user@domain.com",
      "pass": "password"
Update the host, user and pass with your details. If you’re using an EU instance, then the host can stay, otherwise, change it as needed.
Perfect, thanks a lot MichaelBrooks, the host was the issue even though I use the EU host :slight_smile:
It works now fine, thanks a lot :slight_smile:
Warm regards
There is only one issue I have now again :frowning:
Even though I have:
“mail”: {
“from”: “‘Tischer.io’ sebastian@tischer.io”,
It show me strange from addres and strange email symbols. Do you know where I can change this?! :)
