I have lots of posts for “paid-members” only. What query to use in mysql ssh “find and replace” to change visibility of posts from paid-members to public?
It’s suggested that you use the Ghost API rather than directly modify the database since the API will prevent you from breaking things :) I think you need to update the visibility field to public
Hi,I never worked that way. How to use it? configuration file, ghost cli?
You’ll need to create a custom integration so you can get an Admin API key:
From there, you’ll need to write a script (nodejs is suggested since there is the @tryghost/admin-api package that does a lot of the heavy lifting for you) like this:
(haven’t tested but do something like this):
const GhostAdminAPI = require('@tryghost/admin-api');
const api = new GhostAdminAPI({
url: 'http://localhost:2368',
version: "v3",
key: 'YOUR_ADMIN_API_KEY'
// 1. Get a list of posts which need to be updated (we only need the post id)
const postsToConvert = await api.posts.browse({
filter: 'visibility:paid',
fields: 'id'
// 2. Update the posts
for (const post of postsToConvert) {
// This updates posts 1 by 1. If you need to go faster, you can parallelize this
await api.posts.edit({id: post.id, visibility: 'public'});
