Moved Permanently. Redirecting to https://XXXXX
Hi, I am currently running ghost on docker, with a load balancer in front of it, and I get this issue which I don’t understand:
ubuntu@qcloud:~/data/compose/ghost$ curl https://blog.xoxox.io
Moved Permanently. Redirecting to https://ghost/
the following is the my settings of everything
Ghost Version: docker image: ghost:1-alpine
Ghost compose file:
blog:
restart: always
ports:
- 2368:2368
volumes:
- ~/data/docker_volumes/ghost/content:/var/lib/ghost/content
environment:
- MAIL_FROM=will@xoxox.io
- url=https://blog.xoxox.io
Nginx compose file:
proxy:
image: nginx
ports:
- “80:80”
- “443:443”
volumes:
- ./certs:/etc/nginx/certs
- ./conf.d/blog.xoxox.io.conf:/etc/nginx/conf.d/blog.xoxox.io.conf
Nginx conf:
upstream ghost {
server qcloud.xoxox.io:2368;
server {
server_name blog.xoxox.io;
listen 80;
server {
listen 443 ssl http2;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_certificate /etc/nginx/certs/blog.xoxox.io.crt;
ssl_certificate_key /etc/nginx/certs/blog.xoxox.io.key;
client_max_body_size 0;
location / {
	proxy_pass http://ghost;
PS: if I remove url environment variable, it goes right,
but the blog site does not handle links right.
If you are running multiple instances of Ghost for the same blog that won’t work. From the install docs:
You’re nginx config is not passing the necessary headers through to Ghost so it won’t know what URL it’s serving. Ghost-CLI is the recommended/supported way to install Ghost, it has nginx templates that you should follow if installing your own way.
according to docker-compose.yml of ghost, it runs just 1 instance. and the url nerver changed.
You’re good on the multi-instance side of things then but you’ll still need to fix your nginx config for Ghost to work correctly.
after I added the following headers from templete nginx file to conf
nothing changes
thanks anyway
Just to be sure, check where the node.js port is listening to, as well as your blog sudo netstat -peanut
Also why are you proxying to ghost.org?
Try changing that to:
where 2368 is the port where node is running or put whichever server you’re using
nginx is not on the same node which blog is deployed. nginx is deployed in USA, but blog is deployed in China, I am sure the blog is accessable, because if url is not set in the environment, redirect is successful.
above line is just pointing to the upstream:
upstream ghost {
Looks like I’m having related issue: https://forum.ghost.org/t/http-x-forwarded-proto-not-used-by-all-requests
i.e. when i change the http to https in the json config (url variable) i see the same Moved Permanently status and infinite redirect loop in Chrome.
